B18c Supercharger setup
Old May 20, 2002 | 01:37 PM
SCsol's Avatar
Default B18c Supercharger setup
guys im thinking of adding a jackson SC to my ITR motor. is there any problems with the jackson SC. and what compression ratio would be best if i were to use a GOOD pistion ie JE. and what kind of HP will this setup made if tunned, thanks for your help
Old May 20, 2002 | 01:47 PM
TurboSohc's Avatar
Default Re: B18c Supercharger setup (lowsol)
Have you tried the search function? Anyways stay away from the jrsc. Your intake temp's will be very very high and will cause major heat soak. I would say go turbo or better yet all motor. Yes JE pistons would be alot better if you plan on upgrading to a larger pulley. Tuned with the stock pulley I would say maybe 220whp.
Old May 20, 2002 | 01:59 PM
SCsol's Avatar
Default Re: B18c Supercharger setup (TurboSohc)
i did search (36 posts). heat soak, could that be reduced? what about a 1" carbonfiber plate between the SC and the block? would that help
Old May 20, 2002 | 03:26 PM
Captain Save-a-Hoe's Avatar
Hondata makes an intake manifold gasket to reduce heat soak.
Old May 20, 2002 | 04:38 PM
boostin GSR's Avatar
Default Re: B18c Supercharger setup (Racing Hartless)
jrsc with front mount intercooler!
Old May 20, 2002 | 04:50 PM
SuperTeg's Avatar
Default Re: B18c Supercharger setup (BoostinGSR)
Why would you diss a JRSC? I have a 95' GSR with a JRSC and I am currently at 10+ psi w/ hondata and I have no complaints with the power. At 6psi, Vafc, map mod, and 10 deg timing I made 227 hp. Now I should be around 260ish. I havent' dynoed since I upgraded the boost. My 1/8 mi times at 6psi were 8.44 at 83 mph. With AC, PS, and ABS still activated and functional. I am a very happy customer with my JRSC. The JRSC can be a great power adder if you pick the right products to add on, but it can also kill your motor if you don't use some common knowledge. I say go with it if that's what you want. Good luck
Old May 20, 2002 | 05:27 PM
not that simple
jxj220z28
Aug 23, 2005 04:35 PM
icelarry27
May 1, 2003 07:58 PM
jaM3s Bond
Feb 22, 2003 04:07 PM
yellowbuffalo
Feb 1, 2002 03:18 PM
pstreck
Aug 21, 2001 02:20 PM
