JRSC Question
Old May 19, 2002 | 01:11 AM
JRSC EM1's Avatar
Default JRSC Question
I went to the track for the first time since I got the JRSC installed a few months go and I want to know if anyone else has had this problem. On the back side of the motor there's a coolant hose that connects to the TB from the head ( I think its the head it's late and I can't remember). The heater control valve that sits directly underneath it is repositioned when the sc is installed. Has anyone had a problem with this heater control valve rubbing a hole in the coolant hose that goes into the TB? It happened both times I ran, I spilled coolant in the pits like a ****. Its a good thing I had the same size hose in my toolbox and alot of water. I do have the ES mount inserts so the engine torques less than with just the stock mounts. Anybody have any ideas on how to fix this? Tomorrow I'm going to wrap this hose with a larger size hose and ziptie it in place. BTW for the first time at the track with the JRSC and Kumho tires I ran a 14.3 @ 99.5 mph, sucky 60ft 2.2 , and a .503 reaction time. Any help or ideas would be appreciated. Thanks.
Old May 19, 2002 | 01:53 AM
sgT's Avatar
sgT
Default Re: JRSC Question (JRSC EM1)
remove both coolant lines from both
you dont need them.
Old May 19, 2002 | 09:03 AM
JRSC EM1's Avatar
Default Re: JRSC Question (sgT)
How and with what should I plug them up?
Old May 19, 2002 | 12:35 PM
senpai's Avatar
Default Re: JRSC Question (TanabeGSR)
Probably 99-00 SI coupe
Old May 19, 2002 | 02:13 PM
JRSC EM1's Avatar
An Ebp '00 Si.
Old May 19, 2002 | 02:14 PM
JRSC EM1's Avatar
EM1 = 99-00 Si
carbonlaced
Mar 16, 2006 10:28 AM
MartyMarGSR
Aug 9, 2005 03:45 PM
boostedeghatch
Jun 20, 2005 10:49 PM
WS6Dreams
Aug 23, 2003 04:57 PM
siis2fast
Apr 26, 2003 10:20 PM
