turbo sizing ?
Old May 22, 2002 | 08:34 AM
RCSIVTEC's Avatar
Default turbo sizing ?
whats up guys i wanted your suggestions on what size turbo to go with my options are a xs enigneering to4x,to4x2 or a garrett t66 or a turbonetics t60-1. my setup is a crvtec with a86mm bore ge iron sleeves,blue printed and balanced with a counter blanaced knife edged crank,je pistons and pauter rods,a ported out and polish b18c5 head with a complete ferrea valve train either top fuel turbo spec cams or the new jg eldbrock turbo cams. my fuel setup is a 15 gallon fuel cell with and aeomotive elimantor pump and another aeromotive a1000 pump feeding through -10 fuel lines with a aeromotive fuel filter and fuel pressure regulator with four primary 750cc and four secondary 1000cc injectors. all this controlled by a haltech e6k with direct fire ingiton.
what do you guys think. all of this is going into a 00 civic si.
Old May 22, 2002 | 08:39 AM
immortal's Avatar
Banned
Default Re: turbo sizing ? (RCSIVTEC)
go big or go home. thats my motto.
try innovative turbo systems
http://www.innovativeturbo.com
i'd take them over turbonetics and xs-engineering
Old May 22, 2002 | 08:41 AM
RCSIVTEC's Avatar
Default Re: turbo sizing ? (immortal)
you bet your *** i want to go big i was thinking of a greddy t78 or even a t88 with the type of $$$ i am putting down on this beast. bigger is always better.
Old May 22, 2002 | 08:58 AM
paulzy's Avatar
a 62-1 should be good enough
Old May 22, 2002 | 10:43 AM
shifthard's Avatar
hehehehe
got any pic of all this you're trying to set up
Old May 22, 2002 | 10:47 AM
RCSIVTEC's Avatar
Default Re: turbo sizing ? (shifthard)
sorry dude i dont have any pics all i have rigt now is the block and its at ge right now getting the ge treatment.
Old May 22, 2002 | 11:01 AM
Liltrix's Avatar
T66-1 and go to XS Engineering or buy one from Turbonetics through Dynamic Autosports.(In that order), there is a specific reason for buying through DA. send an IM if u wanna know the reason.
I chose XS and I am very very happy, the only draw back with them is that they dont give out their specs. U have to fill in a form with everything U have and what U want to have at what boost and they will give U a custom turbo. I was able to measure the compressor and it is identical to a 60-1. I get boost at about 3~3500 RPM all the way up to 10k.
Given what U have I would get a T66-1. I presume that this is going to be a drag only car?
Do U really need all that fuel?????????
[Modified by Liltrix, 3:03 PM 5/22/2002]
Old May 22, 2002 | 11:08 AM
RCSIVTEC's Avatar
Default Re: turbo sizing ? (Liltrix)
thanks for the info i was pushing more towards xs engineering i think that there t04x2 is as big or bigger than a t-66. no its going to be a street car to take to the races and the hangouts here in miami. i am not 100% sure that i am going to need all that fuel but better safe than sorry.
Old May 22, 2002 | 11:25 AM
Liltrix's Avatar
I just have 720cc injectors and its a challenge to tune it properly for the streets and it consumes quite a bit of gas and well sounds like a race car on the street. I dont mind that though, I am having a lot of fun with the car.
But I am seriously considering running 310cc primaries and 550cc secondary secondaries. this is much better for a street beast, that hangs out at the track on weekends. this config will allow U to start and run like a stock car on the street and when duty demands it the secondaries will be more than enough for big boost street/ strip.
I am running a DFI 7 though. That might be the only difference
Old May 22, 2002 | 11:31 AM
RCSIVTEC's Avatar
that did run by mymind that the 75cc's might be a pain in the *** for the street as primary's i might reconsider and go with 45 or 55cc as primary and keep the big boys for the secondary.
Old May 22, 2002 | 12:49 PM
paulzy's Avatar
street car? Why such a big turbo?
Old May 22, 2002 | 12:54 PM
RCSIVTEC's Avatar
Default Re: turbo sizing ? (Slow_ass_4dr)
like they say bigger is better. i am building the car mainly for the track but also to have some fun on the street.
JacksonD
Feb 28, 2010 06:02 PM
zeroz
Apr 16, 2005 08:33 PM
Johnny_Rocket
Mar 3, 2005 10:18 PM
ofl
Aug 11, 2004 05:19 AM
gliaw
Mar 13, 2003 11:29 AM
