Oil return fitting placement
Old May 21, 2002 | 08:24 PM
racerxadam's Avatar
Default Oil return fitting placement
So i got around to welding my return fitting on my oil pan and then i put a cap on it until i get everything on and running. just one step out of the way. but my concern is that if i take the cap off oil comes gushing out of the fitting. the car is just to the full line on the dipstick and the fitting is as high as it can be and still allow another fitting to be attached. I'm concerned that this will back up the oil in my turbo and cause blown seals. Anybody have a good pic of where they have their fitting mounted and how long its been like that without problems?
Old May 21, 2002 | 08:26 PM
dustin's Avatar
Default Re: Oil return fitting placement (racerxadam)
When the motor is running, much if the oil is actually coating the inside of the motor... and the level drops. You'll be ok as long as the fitting is close to the top of the pan.
mine:
Dustin
Old May 21, 2002 | 08:52 PM
yellow blur's Avatar
Default Re: Oil return fitting placement (dustin)
Looks like you could give kabir a few welding lessons
(HAHAHA j/k kabir)
Ed.. who's return line fitting weld is leaking
Old May 22, 2002 | 03:20 AM
racerxadam's Avatar
thanks dustin. thats what i was thinking. i just had to make sure
FearTheH
Apr 15, 2009 05:52 PM
bb_one
Jul 17, 2006 10:49 PM
hackish
May 17, 2004 09:45 AM
torr
Apr 14, 2004 07:48 AM
dunkd
Mar 5, 2004 09:54 AM
