$5000 Question
Old May 22, 2002 | 08:31 AM
Madness's Avatar
Default $5000 Question
ok--- the time has come
i've decided to go turbo ( yea i know finally. its about time yeayeayea)
what i need is some opinions / pointers
i'm starting with a bone stock 95 gsr (83000 mi) and a $5000 budget
looking for ~300hp and daily driven reliability
Considering the following
Drag III
Hondata 2b (if $ allows)
Act XT/SS clutch kit
Toda flywheel (if $ allows)
RC 550 injectors (if $ allows)
Eagle rods
JE 9.0 or 9.5 pistons
Cometic headgasket
Race engineering blockguard
honda engine bearings
new rings
any suggestions?
how would you spend the $ to do this?
Old May 22, 2002 | 08:36 AM
immortal's Avatar
Banned
Default Re: $5000 Question (dante_420)
dump the block guard
dump the flywheel if moeny does not permit
priority :
1. turbo kit
2. hondata & injectors (they go hand in hand)
3. clutch
4. pistons/ rods / bearings / gasket
Old May 22, 2002 | 09:34 AM
KStuned's Avatar
Default Re: $5000 Question (immortal)
I hate to say it but I dont think $5k will do it. Not for built block, hondata and your turbo. **** gets expensive FAST!
Old May 22, 2002 | 09:44 AM
ExospeedAMcrx's Avatar
To complete your 300hp turbo project, even though $500 is a lot of money, it is still short a feew hundred $ to get the other parts that you need.
Here’s an example of a price breakdown:
GSR built blocks, pistons, rods, new bearings, etc $2100.00
DRAG 3 turbo kit $2795
Stage 3-4 clutch kit $300.00
This is a good start up.
With this setup you can probably boost 10lbs safely
And look into upgrading the injectors as the next step to your boost goals.
Overall this is a dope startup on a project. You can just get the hondata, electronics after you get this all setup.
Good luck
Wil
Old May 22, 2002 | 09:49 AM
turbo_ef9's Avatar
Default Re: $5000 Question (exospeedAMcrx)
if you looking for a drag kit i will sell you one brand new with reciepts etc for..... 2400 shipped
Old May 22, 2002 | 10:05 AM
Rain_man's Avatar
New User
Default Re: $5000 Question (b16_ef)
I'd go with Immortal's priority list.
But go with the max rev kit. Drag includes stuff you don't need if you get Hondata, and Hondata is the only way to go...
MaxRev kit 2700
Hondata 550
Injectors 270
Thermal Exhaust (good for 20hp I recall) 550
Clutch 400.
With leftover 500, you can do use it for the DIY Wideband or Electronic Boost controller (quicker spoolup) or tuning.
That's about 5k and should get you about 300whp depending on how much boost you run.
Itbdennis
Jul 28, 2005 03:26 AM
dubbs
Feb 11, 2004 09:21 PM
1badITR
Jul 19, 2002 09:42 AM
IgniteTeg
Aug 25, 2001 10:37 AM
