what do i need to make DSM 450 INJECTORS to work in a 99 TURBO LUDE?
New User
by taking the DSM 450 injectors what do i need to make them fit in a 5th gen lude? also with the 450 injectors would i need a vortech 12:1 fmu or not? thanks ~ still trying to boost the lude.
Re: what do i need to make DSM 450 INJECTORS to work in a 99 TURBO LUDE? (ELUD THS)
You won't need an FMU with 450cc injectors. You will need a resistor box and some different injector clips. E-mail me if you need some clips.
Sonny
Sonny
Re: what do i need to make DSM 450 INJECTORS to work in a 99 TURBO LUDE? (DLB1994)
Well if you just run off the 450 injectors with no fmu or any other form of fuel management, prepare for a big boom. You will run lean and detonate the second you hit boost. To make 450 run with no RRFPR you will need a standalone or some sort of piggyback that will add more fuel per boost.
Re: what do i need to make DSM 450 INJECTORS to work in a 99 TURBO LUDE? (GottaLude)
i thought that in the afc hack, you just set the unit to -40% all the way w/ 45cc dsm injectors. isn't that just controlling voltage so that the MAP sensor won't see boost and not fuel? correct me if i'm wrong since i'm new to turbocharging and need as much info as possible. thanx
Layziebtnh055
10-09-2004 03:48 PM
