Help with SpeedPro installation
Old May 20, 2002 | 04:56 PM
blownsi's Avatar
New User
Default Help with SpeedPro installation
I'm using a SpeedPro bank to bank ECU along with the Honda specific wiring (not the generic GM style harness) harness on a 97 LS. The IAC connector on the wiring harness has 4 wires, but the IAC connector on the intake manifold is only 2 wires. Is there a specific IAC connector needed to run with the SpeedPro or is there a way to rewire it?
Also, the SpeedPro came with a 4 plug injector wiring harness but it doesn't specify which plug goes to what injector. Each plug has a common red wire and the other 4 are a different color. Thanks for any help!
Old May 20, 2002 | 05:19 PM
SEFIxCivic's Avatar
Default Re: Help with SpeedPro installation (blownsi)
you cant run your honda iac. you gotta run the gm one. alsi it doesnt matter which plug goes on waht injector for bank to bank.
Old May 20, 2002 | 05:30 PM
SEFIxCivic's Avatar
Default Re: Help with SpeedPro installation (SEFI8LOxCivic)
they have an adapter you can buy to run the gm aic. it cost about 75 bucks you can buy it at force-efi.com
Old May 20, 2002 | 06:07 PM
blownsi's Avatar
New User
Thanks Drew! Any tips on a first time start up with the SpeedPro?
Old May 20, 2002 | 06:17 PM
SEFIxCivic's Avatar
make sure you get the timing matched on the timing gun to whats indicated on the timing map before you go driving around. if its totally off play with the crank reference angle parameter. off of memory the # should be somewhere around 56 degrees + or - 5 let me know how it goes.
Old Sep 21, 2002 | 10:34 PM
TurboDANDEE's Avatar
Hey, what part of the website is the IAC adaptor at??
Old Sep 22, 2002 | 10:26 AM
Hispeed's Avatar
I will give you a freebie on the injector question
injector 1 = brown/red
injector 2 = black/red
injector 3 = green/red
injector 4 = yellow/red
Oh and the car will run just fine without the iac valve. I don't use it and still have a stock idle.
[Modified by GSRev, 11:31 AM 9/22/2002]
Old Sep 22, 2002 | 10:30 AM
Default Re: Help with SpeedPro installation (GSRev)
is #1 coming from the pulley side or distributor side?? I dont know if i did mine right, but my yellow/red ended up on the distributor side.
Alex right?? hey this is Dandee, Im trying to get my wiring done, u think u can give me a hand??
[Modified by JiSATSU RaceR, 7:32 PM 9/22/2002]
Old Sep 22, 2002 | 10:32 AM
Hispeed's Avatar
Default Re: Help with SpeedPro installation (JiSATSU RaceR)
#1 is the number 1 cylinder which is the pulley side
Old Sep 22, 2002 | 11:52 AM
turbo Si's Avatar
LOL!!! Come on Dandee.......you know the cylinder order! What's up Alex, how's it goin?
Old Sep 22, 2002 | 11:57 AM
hondaswaper's Avatar
Default Re: Help with SpeedPro installation (turbo Si)
what motor do you have??
i have lots of speedpro programs saved........
hit me up on AIM: HondaSwaper
Old Sep 22, 2002 | 12:18 PM
shut up buster, the one with the yellow wire has a #1 etched on the clip.
Old Sep 22, 2002 | 01:58 PM
Hispeed's Avatar
dandee,
Hey PM me with your number.. I will give you a call to give you a run down on what goes where.
Old Sep 22, 2002 | 08:46 PM
I dont know how to PM hahaha. but my number is 832-236-3303.
GrimLude
May 13, 2014 11:24 AM
B_Swapped93
Mar 7, 2014 04:54 PM
alexdelsol94
Mar 2, 2009 06:32 PM
nytosc
Feb 25, 2009 06:49 PM
j spec
Jul 30, 2006 04:57 PM
