DOH!! DRAG manifold bolt on turbo is brocken!
****! The right rear bolt which hold the turbo on the manifold is broken. I can not screw it in anymore and I can't get it out, cause the downpipe is in the way.
I guess I have to remove all that **** and replace all the 4 bolt with studs and copper nuts. 1 day work again and then quicker turbo spool up
Re: DOH!! DRAG manifold bolt on turbo is brocken! (austrian type-R)
not just bolts -- I had 4 studs with copper washers on my maxrev manifold to turbo.
I lost one lock washer and the stud without the lock washer stayed on and the other 3 studs totally backed out. Got bolts in there now , till i get studs welded in from the back of the manifold
