which head should i use
Old May 29, 2012 | 02:58 PM
legend97's Avatar
Default which head should i use
I have a gsr motor than im goin to boost. Im going to get the block sleeved but my question is should i use the gsr head or b16? Thanx in advance for any advice.
Old May 29, 2012 | 03:10 PM
TheShodan's Avatar
Moderator
Default Re: which head should i use
Won't matter. Keep what you have.. you'll be fine. For FI, there is no advantage of either one or the other, except for the camshafts, in which GS-Rs are preferred.. Therefore, keep what you have..
/thread.
Old May 29, 2012 | 03:12 PM
4genaccordfreak's Avatar
GSR head for sure. the smaller "quench" area promotes a much better swirl effect and atomization of the air/fuel mixture, as well as centralizes the mixture around the spark plug and keeps the burn path in the middle of the piston for an overall stronger power stroke.
But like Shodan added, for FI application the head's will react in the same fashion. An N/A application is where what I said above really comes into play when you try to take the most advantage of the combustion chamber design to net you a more efficient and powerful burn.
The B16 head will do just fine, but if you have a choice go with the GSR head.
IMO the best designed Honda B-series head from factory.
Old May 30, 2012 | 03:27 PM
legend97's Avatar
Thank you for the advice. I just got into the honda game even tho ive always loved them. I bought a wrecked gsr teg but some ppl say b16 is better but most ppl i here that go oost they use gsr head.
Old May 31, 2012 | 01:25 AM
Schister66's Avatar
Man U FTW
Stick with the GSR. The only downside is that the GSR head runs a different IM flange than the B16/B17/ITR which makes finding aftermarket intake manifolds marginally more difficult. The GSR cams are better than B16 which offsets the previous issue.
Old May 31, 2012 | 05:00 AM
secondlife2's Avatar
im running a GSR head on my set up
Old May 31, 2012 | 05:06 AM
boosted_D's Avatar
GSR head with stock intake manifold gutted and ported, or with a edelbrock Intake manifold.
If you already have a B16 head as well, you could use that with the GSR cams to the same effect.
Old May 31, 2012 | 04:30 PM
95dxsir2's Avatar
i thought the B16 head flowed better than the B18C?
Old Jun 1, 2012 | 02:40 AM
TheShodan's Avatar
Moderator
Incorrect
Old Jun 1, 2012 | 04:48 AM
rich7777's Avatar
And ??
There the same. If there is a difference then it's nothing you'll notice. I prefer the GSR head to the B16 head personally. I like the quench areas it has. But again, in reality I doubt you'll notice a difference between either head.
Old Jun 1, 2012 | 07:15 AM
legend97's Avatar
I do not have a b16 head, just complete gsr motor.
Old Jun 1, 2012 | 11:06 AM
TheShodan's Avatar
Moderator
OK. Fine, then please keep what you have.. question asked and answered.
Good luck to you.
Old Jun 1, 2012 | 09:11 PM
PURPLERANGER's Avatar
GSR if you can actually find one, just for the whole "quench pad" but around here in Kent, WA they are almost none going for sale, but a B16 that's all you can find for a good rpice, plus they are somewhat more available I believe.
HondaAP1
Apr 19, 2009 12:17 PM
bullet647
Jul 15, 2007 09:19 PM
fliptout
Apr 4, 2007 07:39 PM
blowme
May 24, 2005 05:37 PM
Tyson Ballou
Dec 26, 2001 06:17 PM
