Preparing for more boost, criticize pls?
Current mods in sig.
I have a 10lb spring, and I'm going to be buying a manual boost controller. Shooting for 12-16lbs on a stock motor.
Things I'm changing/adding
1000cc injectors
ARP head studs
New clutch soon
Boost controller
And obviously a dyno tune.
Should I worry about my fuel rail or just keep it stock?
ALSO! I have a rebuilt gsr head, should I just slap that bad boy on instead of reusing my stock head? My block is stock, and I am worried about throwing a rod, melting a piston and damaging my head. I bought a lsvtec motor a few days ago and I am in the process of buying rods and pistons, but I am no hurry to do so, and if I use the gsr head, I won't be running as much boost, probably 12-14lbs which is 300-330whp. I want to keep it as safe as possible with the stock block.
Opinions, knowledge, criticism welcome, Thanks.
1000cc injectors
ARP head studs
New clutch soon
Boost controller
It came with the stock one and I don't have any interest in dropping a couple hundred for a ported one
I do see a 68mm blackworks TB on craigslist, would I benefit from that? **** just remembered I need a MAP Sensor too -_-
if youre reluctant to buy a skunk2 im, would u buy a vtec conversion kit?
if not stay ls. on average a ls hits 300whp at 14psi. u can save money for your lsvtec build by staying ls for now.
a 10psi ls is pretty quick
A conversion kit consists of a head gasket, sandwich plate, a plug and the oil line? I planned on buying the plate and hg separately, and I have the line already, unless i'm missing something?
cool. I wish I had my motor here with me so I can understand the gsr head better.
So there is only one oil line feeding into the block, and is that it for oil lines? The guy I bought the motor from said I have to buy an oil pressure switch, will oil be routed to this?
Last but not least, my ecu is currently chipped. Will I need to buy a vtec ecu kit or anything of that nature before I bring it to be dyno tuned?
alright so will I have to wire anything for vtec? I was under the assumption I have to wire the vtec to the ecu, plus do something with the knock sensor. know I have more research to do, I think I only have to solder a couple plugs from the gsr harness I got, not too sure yet, my motor is ob1 and the harness i got with the motor is obd2
so i've read concluded this kit needs to be installed into my p75 in order to run vtec.
http://www.xenocron.com/vtec-convers...b2871d9fc398cc
Also i'm guessing I have to wire it like so? but this image doesnt go into detail.
Which turbo are you running? That makes a big difference in your plans.
-keep the stock fuel rail
-get a 3bar MAP
-convert to LS/VTEC and port the stock GSR IM...take the butterflies out and clean it up with a dremel (the cheap way to make something similar to the Skunk2)
-reliable boost controller
-retune ... if you have access to E85, that adds a bit more safety into the equation (since its ~106oct)
-get a 3bar MAP
ekhondahudson
Mar 17, 2014 03:46 PM
