Question on inlet//outlet 2 bolt adapters
Old Jun 12, 2012 | 04:13 PM
vtak2nr's Avatar
Default Question on inlet//outlet 2 bolt adapters
i bought an airesearch t3 60/.63, thing is, instead of having protruding cylindrical inlet//outlet it has a flange for 2 bolts
pic for example
but im having a hard time finding a *t3* inlet//outlet adapter. i find t25, t28, gt28 etc easily
example
http://www.ebay.com/itm/Turbo-Compre...ht_1594wt_1163
now will a t25 adapter fit a t3? if not, where am i supposed to find for a t3? thanks
Old Jun 12, 2012 | 06:28 PM
TheShodan's Avatar
Moderator
Default Re: Question on inlet//outlet 2 bolt adapters
You mean like a T04B smaller housing? what's the compressor wheel used?
Old Jun 13, 2012 | 06:48 AM
xile6's Avatar
My t25 from an sr20 has that flange.
The best thing to do is get a ruler and see what the size is then look at the t25s and see if you can get one to match.
Old Jun 13, 2012 | 05:19 PM
vtak2nr's Avatar
compressor wheel: 46.5 / 60.1 mm 60 trim
compressor housing: 0.60 a/r
what size are the t25's?
someone told me that a standard 38mm WG flange would work for the compressor outlet and the inlet flange can be found at any muffler shop for like 5$, but i would need to get pipes welded onto the flanges
thing is, i want to find a flange with the pipe already on, like the ebay link above
Old Jun 14, 2012 | 07:11 AM
xile6's Avatar
Its a t25 from a nissan here is the specs.
Compressor Specs 1.70" Compressor Inlet, 42.81mm inducer,60.00mm Major ,.80 A.R.
exhaut specs are, .86 a/r, 52.6in, 45.47ex 73trim
also this is how i welded my flange on
http://i23.photobucket.com/albums/b3...223_183832.jpg
Its a steel flange and i weld on a pipe.
And on the outlet pipe you said a 38mm wg flange might work. Well if you wanna take a ruler to it i can check for you. I have like 3 38mm flanges in my garage. ill take a ruler to them and post it up so you can see if it is around the same size.
Other then that you can find someone that welds alumi good.
and click the link in my sign. Aem fic up and running. It has more information about my turbo kit.
The turbo is lovely it spools so easy @ any rpm.
oneludesol
Apr 30, 2008 04:27 PM
crispydee
Aug 25, 2005 10:30 PM
scooter
Jun 24, 2004 03:42 PM
bryan305
Sep 12, 2003 08:26 PM
