Ebay Turbo Questions!
Old Jun 14, 2012 | 04:34 PM
HondaTurboVtec's Avatar
Default Ebay Turbo Questions!
Hello, I'm a noob and need help for my plans... I'm planning on building a honda civic or any type of honda with a D15 or D16 engine. Here is a link on a Ebay Turbo kit, not sure if it needs customising or direct bolt on? If it will fit all honda d15 or d16? http://www.ebay.com/itm/260777549102...ht_2814wt_1195 I know this thread maybe open before, please I want too build a nice honda
Old Jun 14, 2012 | 04:36 PM
doood's Avatar
been there done that
Default Re: Ebay Turbo Questions!
Old Jun 14, 2012 | 04:37 PM
doood's Avatar
but seriously, unless you like wasting your money and potentially blowing your engine, keep looking.
Old Jun 14, 2012 | 04:38 PM
If ebay turbo kit is not worth, what types are there? what can I do from reducing the potential of blowing the engine?
Old Jun 14, 2012 | 04:45 PM
doood's Avatar
that question right there shows you're not ready for boost. you havent even researched the different quality kits available nor have you stated a budget or power goal.
i predict if you ever do go through with this it's gonna cost you a lot of money that didnt need to be spent.
Old Jun 14, 2012 | 04:52 PM
That is why I stated for some help, as this will be my first time. I know there is some Greddy turbo kits, also engine internals will be changed. Budget wise doesn't bother me, power can be normal I assume 250-350bhp not after really big power.
Old Jun 14, 2012 | 05:23 PM
Dark_Teg's Avatar
The cheapest kit I have seen that is decent is the Treadstone kit. Even if you buy it for $1,700.00 you are still a couple of grand away from having a reliable set-up.
Old Jun 14, 2012 | 05:28 PM
Would this fit aus spec?
Engine internals required?
In other words not worth it or?
Old Jun 14, 2012 | 06:44 PM
grumblemarc's Avatar
The Grumpiest
Read the FAQs. Check the link in my sig. Read the FAQs. Look at comparable builds. Read the FAQs. Oh. Did I mention Read the FAQs?
Old Jun 15, 2012 | 07:27 AM
SiRCiviC94's Avatar
they need some modification to work and the car needs tuned
Old Jun 15, 2012 | 09:15 AM
Hidenplanvew's Avatar
Also a safe range for a d16 is around 220 whp, a D15 is much lower... Your going to have to look into building it
Old Jun 15, 2012 | 09:45 AM
mechanix619's Avatar
I'd stay away from eBay turbo kits. Will they work? Yes. Will they last? No. In the end you'll be re-purchasing parts.
The best advice I can offer is to start reading as much as you can about turbo setups. For the most part everything is straight forward. Determine a HP goal and work backwards.
If you want a quality kit check out the kit offered by SpeedFactory.
http://www.speedfactoryracing.net/st...roduct=1650783
Old Jun 15, 2012 | 12:08 PM
xile6's Avatar
it iwll boost but its not everything you need. And dont run it for high hp.
There are other stuff out out but will cost about double the ebay kit
Old Jun 15, 2012 | 12:13 PM
Dc4LsTeG's Avatar
EK9
Originally Posted by grumblemarc
FAQs. FAQs. FAQs. FAQs?
Old Jun 15, 2012 | 02:03 PM
phaphon's Avatar
Best to do is read and read a lot. Then save up by the time your done reading you can be ready to dive in and get started
Old Jun 15, 2012 | 02:18 PM
The Grumpiest
The EASIEST way to do it is to find a build with the power goal and budget you want to be at and copy it part for part. After that, find a good tuner.
Old Jun 15, 2012 | 08:54 PM
SiRCiviC94's Avatar
high school autoshop tuner
Old Jun 16, 2012 | 12:58 AM
yungkhmer's Avatar
www.go-autowerks.com
Old Jun 16, 2012 | 01:20 AM
rich7777's Avatar
Originally Posted by yungkhmer
Old Jun 16, 2012 | 11:20 AM
Schister66's Avatar
Man U FTW
Read the FAQ at the top of the Forced Induction forum. That's going to be the best place to find information
dc101
Sep 30, 2011 06:38 AM
Jackieboy420
Jul 19, 2010 06:45 AM
Civiclx
Jan 23, 2008 07:32 PM
ProjectEG8
Feb 15, 2007 09:47 PM
Nasty1civic
Dec 20, 2006 04:04 PM
