ls or gsr for sleeving?
Old May 25, 2012 | 11:12 PM
jdm itr integra's Avatar
Default ls or gsr for sleeving?
i want to get a block sleeved but i dont know if i should use a ls or gsr block, let me know what you guys think (goods and bads) thanks
Old May 25, 2012 | 11:19 PM
Dc4LsTeG's Avatar
EK9
Default Re: ls or gsr for sleeving?
search
Old May 26, 2012 | 04:08 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Searching would be the answer...
It depends on what setup you have or want to run. Think about it.
GSR already has a block girdle. Minimal deck height differences. Depending on if you want the 87 or 89mm stroke would be another factor if buying a complete short block. GSR would accept a VTEC head with out a conversion kit. There are many factors. Since you didt give ANY information on the build desired I would highly recommend you stick to D15's.
Old May 26, 2012 | 05:00 AM
Turbo-LS's Avatar
The gsr block has more webbing so technically its a little more sturdy but all in all peopel have been sleeving ls and gsr blocks for years and one fdoesnt perform better than the other. The girdle isnt nessesary but a nice addition. if your going vtec you wont need a conversion kit but againt his is all minimal stuff. the crank can be used from either block and put into either block so that doesnt make any difference. once a b series block is sleeved and done correctly its close to bulletproof reguardless of b18b or b18c
Old May 26, 2012 | 03:50 PM
i want to built a turbo block 83mm, and wanted to know if a gsr was more solid than a ls since it has a girdle????
Old May 26, 2012 | 08:02 PM
Turbo-LS's Avatar
Either one is fine
Old May 29, 2012 | 09:36 PM
ok thanks
Old May 29, 2012 | 09:40 PM
Dc4LsTeG's Avatar
EK9
ABCVTEC
14
Nov 15, 2006 08:59 AM
civiclxb16a
May 16, 2005 08:31 AM
LBDM EK97
12
Apr 12, 2005 03:58 PM
jamal-188
Apr 29, 2002 05:40 AM
