DB1 Ls/Vtec Turbo - What should I expect from this setup ?
Hi
My car is ready and now it's gonna be tuned soon..
What should I expect from this configuration ?
and..
what do you advise me to change before it's tuned ?
b18a1 block with 81.5 mm custom sleeves (pictured below)
Wiseco pistons (8.8:1 CR according to cr calculator - model no : K541M815)
Eagle H-beam rods (model no : 5394)
ACL Race rod and main bearings
ARP Headstuds
OEM headgasket
stock b18c1 GSR head
stock b18c1 intake manifold without the secondary butterflies
blox 68mm throttle body (I also have the stock thr.body but this one's smoother)
1000cc ID injectors, walbro 342 fuel pump, adjustable fuel regulator
stock GSR distributor with bkr7en11 & NGK plug wires
motorola 2.5 bar map sensor
SPA top mount cast manifold
Tial wastegate & HKS BOV
Garrett Turbo T3/T4E, 60Trim, Stage III Turbine (Exhaust : .63 a/r)
Intercooler (22"x8"x3")
3" complete exhaust
Neptune RTP Ecu
and..
ARP Headstuds
OEM headgasket
3" complete exhaust
Neptune RTP Ecu
Re: DB1 Ls/Vtec Turbo - What should I expect from this setup ?
about the same setup I got, I made about 400hp on 18 psi http://www.youtube.com/watch?v=Se7Zu0O6U5o
Retired Moderator
the 60/63 garrett has a small efficiency range. its not a good turbo for your goals.
heres a map for 400hp
heres a map for 350
As you can see, its well into surgeline.. dont expect much from it.
Ditch it and have Shodan make you a silver surfer with a 58lb wheel
And youll need a larger intercooler.
heres a map for 350
What do you think it should be like ?
That's way enough for me. Is it also OK on low RPMS or totally dead. Is it streetable too ?
Well, that's how it was built. I was using this block atmospherically before without any problems, it's re-honed and put turbo pistons now.
sleeves are Turkish-made. Some people use it around 400 hp without any problems. Of course I would like original dartons but this thing was built before I knew anything about turbo Hondas. Maybe next time
My turbo is NOT Garrett 60-1 by the way..
My fuel is 95 OCT pump gas. I just wanted to know how much will this thing make with this configuration, and since I'm still learning, I need to listen to advices.
The Grumpiest
Why do people do builds and not know what power they should be making out of it? Just asking but I think that's the FIRST thing you should know.
Those must be old darton mids....i have them on my build they have much more hole in the flange. I know mine were newer ones with the phosphate coating.
Also i think he is trying to say t3.t4oe 60 trim. Thats the turbo i have we have similar set-ups...im 410whp at 20psi with gsr cams....You can exect 430-440 with good cams. I would think you may have slighly more with top mount as far as peak hp, I wouldnt have gotten a top mount with this turbo tho...
On street don't need 18 psi it just spin tires , I turn down to 10 psi for the street and ran on the track on 10 psi w/slick 12.2@116. on the low rpm t3/t4 spool pretty quick. very streetable
joepiscapo_83
12-01-2004 08:17 AM
