Spawne's supercharged B20, sponsored by DDTECH
Old Jun 1, 2012 | 08:58 PM
Spawne32's Avatar
Default Spawne's automatic supercharged B20
I think its about time i let this one out of the box. Just a little somethin somethin I have been planning for about 2 years now. Its a little over 6 months in the making right now. Im not gonna post any of my HP expectations or anything ill let everyone speculate and flame as needed lol. Theres the potential for turbo down the road but right now for the street im in love with my supercharger kit.
JDM B20B Engine Block
OEM Honda Crankshaft
Crower Steel Billet H-Beam Connecting Rods
Supertech 84.5mm 11.5:1 Compression Pistons
PnP JDM P8R Cylinder Head
33mm Intake/28mm Exhaust Valves
Supertech Dual Valve Spring Kit
Jackson Racing Supercharger Kit
MVM Stepper Pulley
Ported and Polished M45 Blower Case
OEM LS Crank Pulley
Private Label Manufacturing B Series Narrow Header (4-1 2.5" Downpipe)
3" Catco Catalytic Converter
3" VRS Aluminized Steel Cat Back Exhaust Piping
FloPro Baffle Pack Resonator
Solo Performance OE92 (Turbo Style) Muffler
3" Custom Short Ram Intake with 6" Blox Velocity Stack and AEM Dryflow Filter
CNC Venturi Ported 67/60 Throttle Body
ACURA RDX 410cc EV14 Fuel Injector's
Walbro 255lph HP Fuel Pump
AEM Adjustable Fuel Pressure Regulator
3 Gallon (4gph) Methanol Injection System on Devil's Own Proggressive Methanol Controller
93 Pump Gas
b20b back from the machine shop and ready to start building
painted the block gunmetal
crank installed and rotating smooth as butter with great clearances
pistons installed in the block
more work
P8R head ported and polished with 3 angle valve job and backcut valves
some pics of the motor assembled with my ddtech custom regrinds
starting to look like something finally
Old Jun 1, 2012 | 08:59 PM
Spawne32's Avatar
Default Re: Spawne's supercharged B20, sponsored by DDTECH
I will leave you all with this for further speculation.
Old Jun 1, 2012 | 09:24 PM
Khnemu's Avatar
Auto trans? :O
Old Jun 1, 2012 | 10:46 PM
Fink29's Avatar
Looking good. Remember to Locktite those throttle plate screws!
Old Jun 2, 2012 | 02:19 AM
lovehondas's Avatar
awesome build man gl
Old Jun 2, 2012 | 03:47 AM
EsotericImage's Avatar
Retired Moderator
Nice work!
Illl be checking back for updates
Old Jun 2, 2012 | 05:02 AM
LightningTeg's Avatar
Community Builder
Built Auto huh?
Old Jun 2, 2012 | 05:05 AM
Spawne32's Avatar
Originally Posted by LightningTeg
Built Auto huh?
Yes it says b18c on the side because its from a SIR-G.
Old Jun 2, 2012 | 10:04 AM
Retired Moderator
I had a white VC and showed every little finger print..
After wiping it so many times,it got irritating so i just color matched it to CGP
Old Jun 2, 2012 | 11:06 AM
Gunmetal_B20_Hatch's Avatar
in for auto trans results...
Old Jun 2, 2012 | 12:29 PM
sleepencivic's Avatar
He doesnt like to shift,its just too much!
Interested to see the TQ numbers with that auto trans. What stall converter is that?
Old Jun 2, 2012 | 01:33 PM
Spawne32's Avatar
Its not actually white, its just primered, i sat it on there to keep dirt out lol, its covered in plastic as well.
3000rpm street stall max converter custom built from precision of new hampton
Old Jun 2, 2012 | 06:18 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
If you haven't "built" the transmission, prepare yourself for premature failure. Say all you want, I have done a build mildly similar for my wife in the 90's... Good luck.
Old Jun 2, 2012 | 06:25 PM
DDTECH's Avatar
I was rather impressed upon my tuning trip up to NJ when i saw this..
Rob is a good , close friend of mine and I can honestly say if there's someone that has research until he's blue in the face, its him. Even his little stock 1.8 LS motor is pretty strong.. When i got there he was only trapping 88-89mph. After Tuning on eCtune and testing some stuff out at the track, we got him trapping 94mph only on 7lbs.. with IATs well over 170+.. The meth is still in testing stage, but with high boost, and how well this motor is built and going to be tuned, i dont see why 250+ through the tranny would be any problem...hopefully down the line he can build the tranny to take more power.. but we'll see how it does.. I'm expecting a impressive torque monster.
He's doing an auto to be different, although alot of friends including myself and Keon make fun of him, we all know he's doing what he loves.. I felt this car pull really , really well for just 7 lbs and just having a I/h/e..The car is impressive for what it is..
Old Jun 2, 2012 | 07:08 PM
Spawne32's Avatar
Transmission will be built, just trying to figure out what exactly needs to be looked at in terms of hard parts. As far as clutches, engagement time of the shifts and line pressure modifications. Got all that covered. A phantom grip looks to be the only solution right now for getting both wheels to grip. Not something im particularly fond of but alot of the failures associated with the phantom grip are due to improper clearancing of the plates with the spider gears and the gears not being properly faced.
Its been 20k miles since i first stuck the supercharger kit on the bone stock 1.8 b18b. The trans, and the motor have over 200k now on them. When we initially started drag racing with the trans, I noticed immediately slippage afterwards. I changed the fluid, been running royal purple max atf since the beginning, and then the trans was fine afterwards. And it has been ever since. We abused the ever living **** out of this transmission for what seems to be almost 2 years now. Despite that fact Im still confident the new motor would tear it to shreds. My biggest concern out of all the things that can go wrong inside that trans, is the input shaft being just too small in size. Aside from that, being built like a manual trans works to its advantage in many ways.
and as you can see...traction is going to be an issue lol
http://www.youtube.com/watch?v=S8gf6u0oW_k
Old Jun 3, 2012 | 12:30 AM
Dc4LsTeG's Avatar
EK9
In for this. Nice build so far cool to see someone doing something with an auto trans.
You happen to have any in car videos with the previous setup?
Old Jun 3, 2012 | 05:53 AM
Uncle Dave's Avatar
Good to see it finally coming along.
Old Jun 3, 2012 | 08:29 AM
DDTECH's Avatar
We have a vid of us n bombing the car with four people in it LOL
Old Jun 3, 2012 | 09:07 AM
Spawne32's Avatar
That vid is kinda stuck on facebook lol u gotta download it off your phone and send it to me so i can put it up on youtube.
Old Jun 3, 2012 | 09:33 AM
Dc4LsTeG's Avatar
EK9
Can one of you post it up?
Old Jun 3, 2012 | 09:42 AM
Spawne32's Avatar
Id like to point out, the N bombing only happened 4 times that weekend lol we were just dicking around, the new trans will have a trans brake switch of some sort. There is alot of planning still with the transmission going on.
btw, its a 5500rpm N bomb @5psi lol
http://www.youtube.com/watch?v=9_gZG9Zuy7Q
Old Jun 3, 2012 | 09:56 AM
Dc4LsTeG's Avatar
EK9
Just what I wanted to see
What are you tuning with?
Old Jun 3, 2012 | 10:06 AM
Spawne32's Avatar
ectune, because its the only program that supports the tc lockup function.
Old Jun 4, 2012 | 12:45 PM
HeikDiesel's Avatar
In for this. Have you done any dyno tests with your cams vs any shelf units?
Old Jun 4, 2012 | 04:21 PM
LS AzZkIkr's Avatar
I thought the B and H series has the auto trans controller?
