S300 boost control question
Old Jun 22, 2012 | 03:50 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default S300 boost control question
I've searched hondata and other sites but can't get a clear answer. In the smanager your able to activate low and high boost by activating the a/c. Does anybody have any experience with this? I know the hondata system can operate as a boost controller I'm just need to know if engaging the a/c will actually activate high boost, if your setup for it. Thanks
Old Jun 22, 2012 | 05:32 AM
portenio78's Avatar
Default Re: S300 boost control question
When you use pin B5 in the ecu(AC), yes you will enable a high boost by pressing the AC button. Have a low boost setting, then hit the switch and go to your high boost setting. It does not need to be the actual AC switch, you can put a different one there if you want, as long as one end of it is wired to b5.
Old Jun 22, 2012 | 05:39 AM
Cool cool
I have the boost solenoid wired to my A11 (95 gsr) and from what your saying I don't need an additional wire if I want to utilize the a/c button on the dash. But if I wanted to use another button/switch I would have to splice it off the B5 wire, correct?
Old Jun 22, 2012 | 05:47 AM
kbouchard1092's Avatar
That sounds correct. I use A5 for my nitrous control. I didnt realize i could have used the actual A/C switch to activate it tho. I wired my own switch.
I also have the high/low boost switch, but again used a differnt input and wired my own switch.
using the a/c switch is kinda a stealthy approach tho
I like youre clubs lol
Old Jun 22, 2012 | 07:24 AM
kyden's Avatar
Originally Posted by justYncredible
Cool cool
correct. but you do have a few options in the program if you want to use a different ecu pin.
Old Jun 22, 2012 | 07:28 AM
We are always recruiting lol
Old Jun 22, 2012 | 07:30 AM
Coolistic
What button are you using?
Old Jun 22, 2012 | 09:09 AM
lsturbo33's Avatar
Smanager has a dropdown box and gives you like 5 to select from. I selected the same input for dual mapping and hi/low boost table so they both switch at the same time. I have mine wired up to my cutout so when cutout is closed I'm on low boost and conservative on fuel so I get good mpg and look stock with a stock muffler. When I open the cutout it changes fuel/ignition maps(secondary map) and ups the boost by gear(hi/low boost). I dd it and have used it like this for a year and so and it works flawlessly.
Old Jun 22, 2012 | 09:16 AM
I see
So you have a low and hi settings
Have you tooled around the boost by gear settings by chance?
Old Jun 22, 2012 | 09:58 AM
kyden's Avatar
Coolistic
none. i am using boost by gear so it is always on.
Old Jun 22, 2012 | 10:19 AM
Dc4LsTeG's Avatar
EK9
This is what I wanted to do. Never even thought of having the switch for low/high map and the cut out...
Old Jun 22, 2012 | 04:50 PM
lsturbo33's Avatar
I see
Yes. With Hi/Low boost table you are setting up 2 boost by gear tables. I set all my LOW boost table to wastegate duty cycle pressure(8psi). HI boost table is 8-10-20-20-20psi. I'm very happy with the way it works.
Thanks. It's there in the software might as well put it to use since it's a dd and 3" exhaust get's annoying.
Old Jun 22, 2012 | 05:02 PM
TheShodan's Avatar
Moderator
That's only if you're getting the wrong exhaust parts.
bb6kid22
Engine Management and Tuning
Nov 1, 2010 05:03 PM
85
Sep 1, 2010 12:59 PM
TehGhett0P1mp
Jan 7, 2009 09:34 PM
blwn95civic
Apr 5, 2007 09:41 AM
boostincoupe
Jan 7, 2005 01:17 PM
