is it safe?
Old May 25, 2012 | 05:09 AM
DroppedDisaster's Avatar
Default is it safe?
Just picked up a 95 ls at 195k and want to go boost. Woundering if its safe to Turbo cause its kinda high miles. If so what should I run? Anything would help.
Old May 25, 2012 | 05:36 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default Re: is it safe?
Compression test and do a leak down if everything passes then go ahead
Old May 25, 2012 | 09:38 AM
Muckman's Avatar
Moderator in Chief
Also check for oil consumption by looking at the valves if you pull the head or at least the exhaust ports. Oil in the combustion chamber = detonation = good bye.
Old May 26, 2012 | 12:24 AM
Dc4LsTeG's Avatar
EK9
X2 on compression and leakdown test. Then make sure you fix all problems before you turbo it, such as oil leaks, cels, wiring issues, etc.
MADBADGER
Honda S2000
54
Jul 18, 2008 11:26 AM
model x
Oct 26, 2005 02:01 AM
blackeg
Mar 28, 2005 06:10 AM
RuthlessEF-9
Jun 25, 2003 10:36 AM
ceemarun
Jul 28, 2002 01:17 PM
