HELP!!!
Old Jun 12, 2012 | 07:37 PM
p10hlm's Avatar
Default HELP!!!
well i competition clutch twin disk has maybe 1000 miles on it and about a week ago from a stand still i go to put it into first and its like i have to force it in to first but from a rolling stop it slides into gear like butter all the other gears r fine also....we pulled the tranny and check everything and swapped out the gear selector and put the tranny in and the problem is still there...i also replaced all the bushing in the shifter and still the problem is there....and adjusted the clutch rod and problem was still there...fluid is new and at the right level...any info or suggestions would be greatly appreciated...
Old Jun 13, 2012 | 05:59 AM
p10hlm's Avatar
Default Re: HELP!!!
any suggestions guys?
Old Jun 13, 2012 | 11:17 AM
turbohatch96y7's Avatar
Default Re: HELP!!!
Come on bro you been here since 02 your supposed to have specifics in your title.
Have you checked yoour synchros? Have you taken the gear stacks out and inspected all the needle bearings?
You might have better responses in the TRANSMISSION SECTION....
p10hlm
Jun 28, 2012 04:43 AM
jdmej2lolo
Oct 17, 2008 09:13 AM
EdBoon
Apr 25, 2004 06:02 PM
D15VTEC
Mar 19, 2003 05:17 AM
