LSV Turbo 400-450whp low boost goal..
Bottom end:
84x89
Wiseco 9.5:1 84mm Pistons
84mm Darton Sleeved b18b
Cosmic .040 Head Gasket
Eagle H Beam Rods
ARP 2000 Rod Bolts
22t Water Pump
obd2 GSR Oil Pump
Micro Polished Crank
Head:
CNC Ported p72 Head
ElderBrock Victor X ITM
Hondata ITM Gasket
Skunk2 Pro2 Camshafts
Skunk2 Pro Series Dual Valve Springs
Skunk2 Titanium Retainers
Skunk2 1mm Oversized Intake Valves
Skunk2 STD Size Exhaust Valves
68mm Skunk2 Throttle Body
Transmission:
JDM GSR w/LSD
Clutch Masters Twin Disc Clutch Kit
Turbo Parts:
Custom Ram Horn Manifold
44mm Tial Wastegate
GodSpeed t67 T4 .84ar Turbo
Tial Blow Off Valve
3.5" Down Pipe
31x12x4 Front Mount Intercooler
Hondata Boost Controller
Hondata 3 Bar Map Sensor
Fuel Management:
1200 RC Injectors
AEM Fuel Rail
AEM Fuel Pressure Regulator
324 Tec Fuel Pump
Hondata s300 (Boost By Gear)
Shell:
DC4 Shell (street-able)
Function Form Type 2
M/T 24.5x9x13 Slicks
I'd like to get some feedback on peoples opinions on my build. Pics will be posted up soon. Goals are to hit 400-450whp 250-280tq on 10-12lbs of boost running e85. Later I plan on boosting more and boost by gear so I'm not spinning like crazy on the track or streets. My first crazy boosted set up so I'd like to get feedback form the pros! Any advise out there is greatly appreciated! Thanks in advance!
84x89
Eagle H Beam Rods
ARP 2000 Rod Bolts
22t Water Pump
obd2 GSR Oil Pump
Head:
CNC Ported p72 Head
Hondata ITM Gasket
Transmission:
JDM GSR w/LSD
Turbo Parts:
44mm Tial Wastegate
Tial Blow Off Valve
3.5" Down Pipe
Fuel Management:
1200 RC Injectors
AEM Fuel Rail
324 Tec Fuel Pump
Shell:
Re: LSV Turbo 400-450whp low boost goal..
head is all together. short block all together. tranny all together. waiting on ecu and turbo. turbo should be in this week. ecu should be here thursday. if everything goes as planned it should be up and running by nxt week. all parts are accounted for. just have to plastigage bearings to check clearances.
i knew someone was going to ask tht. only reason why is kuz the shop i work for has a real good account with godspeed and the owner has a good relationship with them. so basically got it for free.
saving for a better turbo. but it should do ok for now. whats a good affordable turbo to go with? i was told masterpower is good at a good price? i should talk to atp.
All that work and he shoots for a "Godspeed" turbo.... Its bad enough on a engine with forged pistons and rods. I'm lost....
masterpower, godspeed, insert ebay brand here. all the same.
also, doesn't that turbo have a divided housing? do you have the proper manifold and wg setup for that?
Ok that's fair enough. So if the Turbo fails and takes out the engine it can be justified as the turbo was free.
I say just wait and purchase something proper instead of gambling with that heap of ****.
thanks for the advise. will do. what turbo would you recommend? im guessing garret?
tht is correct. at the moment i have a custom ram horn with a t4 (not divided housing) on a single 44mm v band wastegate.
If you're only shooting for 400-450. Pro 2 cams and T4 turbo are really not needed. If this is your first turbo build, go with a faster spooling T3 based turbo. You wont regret it.
reason for 400-450 goal is just to start off. later after i get more use to driving boost i will turn it up. 650-700 will be the range at about 25-30 lbs of boost. i believe 10-15lbs of boost is a good start off range for the power band im looking to aim for now. as time goes by i will turn it up.
Honda_Fanatic
23
11-09-2007 07:54 AM
