11.5:1 boost safe?
Old Jun 7, 2012 | 08:56 AM
BAp_mobile's Avatar
Default 11.5:1 boost safe?
Whats up HT, got a b18c looking to boost her spec on the motor
B18c 84 mm bore
Darton sleeves
Manley rods
Cp pistOns 11.5:1
Ls crank makes it straight 2.0liter
Blueprinted and balanced
Head has super tech valve spring retainers and valve guides
Stock gsr cams
I/h/e
Skunk 2 intake manifold
Also I am keeping ac/ps
Really looking into the Reaper/ silver surfer turbo
Power goals 350-400 ish it's my daily
Need some input as to if my compressionnis to high to be running daily
And if this setup is good for the goals I'm seeking.. Thanks guys for your input
Old Jun 7, 2012 | 09:07 AM
Dc4LsTeG's Avatar
EK9
Default Re: 11.5:1 boost safe?
Get some e85 and a good tune
Old Jun 7, 2012 | 09:08 AM
VTEC+Mini's Avatar
God I hope not. I'm about to have my stock JDM 18C Type-R engine fitted with a Garrett GT28RS and the compression ratio is 11.1 to 1. The last thing I want is to reduce the reliability or longevity of the engine.
Old Jun 7, 2012 | 09:11 AM
Schister66's Avatar
Man U FTW
11.5 is perfectly fine IF you have the right fuel to meet your goals. A perfect example (allbeit not a great analog) is a diesel engine. They're roughly 15-20:1 compression ratio, but they're built for it and they have the proper fuel for that situation. E85, race gas, pump gas with methanol or even straight pump gas (depending again on your goals) are all viable solutions
Old Jun 7, 2012 | 10:04 AM
BAp_mobile's Avatar
I will be running 93 oct
Again goals are 350-400 hp
Old Jun 7, 2012 | 10:07 AM
BAp_mobile's Avatar
What's good with the silver surfer turbo. I've read plenty good about it.. Will t his turbo be good for the goals I'm seeking
Old Jun 7, 2012 | 10:30 AM
Muckman's Avatar
Moderator in Chief
Im building a 13.5:1 build for E85. E85 LOVES compression.
Old Jun 7, 2012 | 10:54 AM
BAp_mobile's Avatar
Understandable but I would like to keep my 93 oct as 85 is hard to find around town
Old Jun 7, 2012 | 11:16 AM
Muckman's Avatar
Moderator in Chief
IMO its all relative anyways. Youre just going to find the knock threshold at a much lower ignition advance than at low compression. So what? Talk to your tuner. 350hp isnt anything crazy.
Old Jun 7, 2012 | 11:37 AM
BAp_mobile's Avatar
Do you care to elaborate about the knock threshold??
Old Jun 7, 2012 | 11:50 AM
Muckman's Avatar
Moderator in Chief
I dont want to type a novel. Its the point at which you can advance the ignition at a given load/rpm to the point of detonation/knock. Its relative to many factors including fuel octane and cylidner pressure. Cylinder pressure being a product of static piston compression and manifold pressure.
Old Jun 7, 2012 | 12:11 PM
boosted_D's Avatar
Muckman is correct^^^
Yes you can safely boost it and make 400 whp on 93 pump gas.
You just need to be damn sure you have a good tuner, as you will reach your power goal with less timing advance and less boost that a lower c/r motor, as long as there is no knock/detonation your good to go....
The reaper/silver surfer is an awesome turbo, but it is temporarily discontinued for a revamping, so I'm not sure if you will be able to find one???
Old Jun 7, 2012 | 12:29 PM
Schister66's Avatar
Man U FTW
^^PM TheShodan and find out. He's a great guy to work with. I've done business with him in the past and will do more in the future
Old Jun 7, 2012 | 03:37 PM
dcmatt's Avatar
The reaper is discontinued. The surfer is available on marketplace. Awesome turbo built with response in mind. That'll be an awesome setup. Just remember to make sure you use a good Tuner. E85 would be safer then 93 but 93 is def doable for your goal.
radiotech
May 15, 2018 10:26 AM
urie2324
Mar 13, 2013 10:24 PM
bunnyx
Jun 14, 2010 11:07 AM
YellowCivic95
Apr 27, 2002 07:59 AM
YellowCivic95
Apr 27, 2002 12:30 AM
