Broken wastegate bolt in cast iron manifold, fubar'ed?
What a downer.. If i can't get this mother ****er out, no dyno tune for me tomorrow >< I've already inquiried about another turbo manifold on craigslist incase this fails.
I thought about putting something in the hole, and putting loctite in there, let it set, then try to screw it out. There is no access from the bottom of the bolt hole.
Any help appreciated!
Inb4 get a better manifold, I know, I know, I know!! I regret not using anti seize, and reusing shitty bolts ><
Re: Broken wastegate bolt in cast iron manifold, fubar'ed?
Just drill it out and use a longer bolt with a nut to fit the wastegate. I've had the exact same thing happen to me in the past and this is what I did.
Edit, that's if you can't do the above.
^^ exactly what I was going to say.. pb blaster is the **** for stubborn bolts.. if you don't have a drill take it to a machine shop should be like a 20 dollar job.
Who is Mr Robot?
since the wastegate flange is cast into the top of the manifold, this won't work... unless you want a nut sitting inside a manifold runner, just waiting to vibrate loose and grenade a turbine wheel
Yeah, your right lol. I can see the picture property now. I have a mini ram so you can picture how it worked for me.
I thought it was one of those eBay stainless manifolds...
Who is Mr Robot?
its only gonna break if you don't use anti-seize, since the bolt will work harden to the threads.
theauthor17
08-08-2008 11:47 AM
justinCO
01-17-2003 07:46 PM
IntegD
11-18-2002 12:17 PM
