how to connect external wastegate
Old Jun 5, 2012 | 09:40 AM
ritesh's Avatar
Default how to connect external wastegate
hi all i'm confused now cause i searched where to connect my wastegate to the intake or on the IC piping and a few say on the in take and some others say not to connect on the intake ...
cause i had it on the IC piping but i know a guy who owns a fast honda and his wastegate was conected to the intake so i changed mine to...
what do you guys say?? on the intake or on the IC piping.
thanks.
Old Jun 5, 2012 | 09:49 AM
tron_'s Avatar
10 Year Member
Default Re: how to connect external wastegate
Are you running an electronic boost controller or a manual boost controller?
Old Jun 5, 2012 | 10:06 AM
Dc4LsTeG's Avatar
EK9
Old Jun 5, 2012 | 10:10 AM
ritesh's Avatar
i don't have a boost controller jet
Old Jun 5, 2012 | 10:11 AM
ritesh's Avatar
Originally Posted by Dc4LsTeG
lol, i do sound a little stupid when i read it like that...
Old Jun 5, 2012 | 10:20 AM
tron_'s Avatar
10 Year Member
A wastegate is connected differently depending on wether you have an EBC or a MBC. What one are you going to get?
Old Jun 5, 2012 | 10:24 AM
ritesh's Avatar
i have a manual boost controller i think tomorrow i'll buy vacuum lines and install it.
Old Jun 5, 2012 | 10:48 AM
tron_'s Avatar
10 Year Member
One port of the MBC to the side (signal) port on the wastegate. The other port on the MBC goes to vacuum. I personally have a barb in my charge piping just after the turbo that I used.
Old Jun 5, 2012 | 11:21 AM
ritesh's Avatar
my wastegate only has one side port on the top there's just a threaded hole
any suggestions?
here's a pic:
Old Jun 5, 2012 | 11:20 PM
TravisBiggie's Avatar
GOOGLE CAN ANSWER 95% OF YOUR QUESTIONS
WWW.GOOGLE.COM
WWW.GOOGLE.COM
WWW.GOOGLE.COM
WWW.GOOGLE.COM
WWW.GOOGLE.COM
Old Jun 6, 2012 | 04:38 AM
ritesh's Avatar
Originally Posted by TravisBiggie
lol, thanks
Old Jun 6, 2012 | 04:58 AM
EsotericImage's Avatar
Retired Moderator
Some use the intake as a reference point as it shows the true PSI after pressure drop from piping and intercooler.
Most just use the turbo's fitting
Old Jun 6, 2012 | 05:05 AM
skaraider's Avatar
Yeah thats just another port for your Boost control, i believe if youhave a manual boost controller the lower port is used and if you have an electronic one that the top one is used.. I could be wrong correct me if I am
Old Jun 6, 2012 | 05:48 AM
dpetro1's Avatar
technically this in incorrect. not all setups even use a boost controller. the wastegate just needs a boost signal to the bottom port to function on its own. the OP is asking whether to use a boost only reference (pre-throttle body) or a vaccumm source (intake manifold).
while both can be used, wastegate manufactuers will recommend the boost only source, this way the wg diaphragm doesn't ever have vaccumm applied to it.
an MBC will tee into the bottom port, while an EBC used both top and bottom ports.
lol, this coming from a guy who starts tons of threads about every little question and never searchs. practice what you preach. and if you don't have anything useful to contribute, GTFO
Old Jun 6, 2012 | 06:07 AM
skaraider's Avatar
So in a nut shell its up to Manufactuers spec, where the boost control and WG where it needs to be applied so im right and wrong lol.
Old Jan 2, 2013 | 05:23 PM
ritesh's Avatar
Thanks everyone
Old Jan 2, 2013 | 05:59 PM
hondatech2000's Avatar
You can use atp quick fitting that i stalls on silocone coupler after turbo if you dont jave a source on your turbo utself
Old Jan 2, 2013 | 06:49 PM
wantboost's Avatar
Who is Mr Robot?
I don't even....
bigred850
Oct 9, 2011 05:34 AM
SpoolnByYou
Feb 23, 2006 01:17 PM
Azndude1983
Feb 15, 2006 05:28 PM
I Gotta Question
Jan 18, 2004 11:36 PM
Infinity_Racer
Nov 9, 2003 10:41 AM
