ARP washer help!
Old May 24, 2012 | 01:56 PM
JDMCIVIC919's Avatar
Default ARP washer help!
So I bought new arp headstuds and I can't find the washers. Basically I lost them. Do u have to use them? If so can I just get some normal washers like them? Or do they have to be the arp ones?
Old May 24, 2012 | 03:07 PM
phaphon's Avatar
Default Re: ARP washer help!
Arp sells new washers
Old May 24, 2012 | 04:50 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
To be able to torque them properly you need the washers that they supply.
Old May 24, 2012 | 06:19 PM
I.couldnt get the same diameter n width washer from.like auto zone? I need my car running asap
Old May 24, 2012 | 06:51 PM
DO IT ON ALL FOURS
I can assure you they won't have them. Do as you please, when the washer mushrooms out and splits or your strip the block from them not wanting the torque don't say I didn't tell you so. How do you misplace this type of stuff anyways?
Old May 26, 2012 | 12:30 AM
Dc4LsTeG's Avatar
EK9
Yes order them from arp. Dont try and go the cheap way and try and get them from somewhere else it will only end up causing problems that will make things more expensive
DixieEF
Feb 27, 2013 01:19 PM
cibao2ner
Jan 23, 2010 03:32 PM
InDub
May 5, 2007 05:21 AM
wildoutwhitegsr
18
Feb 17, 2006 07:09 AM
freakin
Oct 30, 2005 09:11 AM
