Which sandwich plate, vtec distributor
Old May 30, 2012 | 01:33 PM
TravisBiggie's Avatar
Default Which sandwich plate, vtec distributor
Has anyone bought an ebay sandwich plate and have it be successful? If not, what can you recommend?
http://www.ebay.com/itm/OIL-FILTER-S...b41b34&vxp=mtr
I have a ls block and 98gsr head. The motor came with a obd2 harness, but I am going to use my obdI that is on my running motor. Can someone tell me what plugs I will need from the obd2 harness? Can I just buy a td44 distributor obdI and call it a day? Do the ls and vtec distributors have different electrical plugs? And obd 1 & 2?
http://www.ebay.com/itm/Honda-Civic-...b46133&vxp=mtr
Thanks
Old May 30, 2012 | 01:42 PM
damnilovepuzz3d's Avatar
Default Re: Which sandwich plate, vtec distributor
Can you stop making new threads every time you have a different question?
Old May 30, 2012 | 01:48 PM
Thx for the free bump
Old May 30, 2012 | 01:56 PM
kbouchard1092's Avatar
I would just use the Golden eagle. Ive had zero issues with it. Im sure any sandwich plate would work but you want to make sure youre using a big enough of a line for the head to supply oil. Most of the ebay plates are probably 1/8npt
Youre re using a OBD1 harness from what type of motor? the distributor plugs would be different. Especially if youre using a SOHC harness on a DOHC motor.
Old May 30, 2012 | 03:28 PM
civickiller's Avatar
no difference between v & nonv dist plugs but there are differences between dist ears
if you buy a obd1 vtec dist(only for correct ears) and swap to obd 1 injectors, your obd1 harness is plug and play. only have to worry about vtec wiring.
but they do make dist jumper, which is cheaper than a whole new dist
http://www.phearable.net/shoppingcar...-c-28_130.html
Old May 30, 2012 | 07:02 PM
I have obd2 injectors but they will work on my obd1 harness no problem. I planned on buying a b16 obd1 dist.
I am using my ls harness for lsvtec
Joacnel
Engine Management and Tuning
Apr 4, 2012 07:02 PM
T3T4Honda
Dec 6, 2008 07:30 PM
97L-esVeeTeg
13
Jun 2, 2004 12:21 PM
jeremy.
Dec 19, 2003 07:40 AM
HX_Guy
Jan 3, 2002 01:32 PM
