LS-T t3/t04e turbo, sputtering problem when accelerating. Help!
Old Jun 4, 2012 | 09:54 AM
ef8sleepr's Avatar
Default LS-T t3/t04e turbo, sputtering problem when accelerating. Help!
Ok. So I just finished my turbo setup, it's a 95 integra ls with a cast manifold, t3 to4e .50 a/r. 440cc precision injectors, open downpipe, 2.25 coldside pipes, 2" hotside. stock map sensor, ngk 7's, ebay bov, and tial wastegate. basemap is on chrome. ok after getting a basemap from xenocron's website, i got the best that matched my setup. the problem is when i put any load on the gas, it's start sputtering and backfires like crazy. I can't even build boost. until i granny shift to 5th gear and lightly open throttle then it'll creep up to like 1 to 2 psi. i tried 3 different basemaps. still no go. My questions are, i used the da obd1 ecu to get chipped instead of my stock p75 ecu to get chipped, will that cause a problem? also my check engine light is on due to the fact that chrome wasn't working at the time and my friend couldn't clear the check engine light and other stuff. what else can cause sputtering and almost like fuel cut when load is applied?
Old Jun 4, 2012 | 10:16 AM
Arthas's Avatar
Default Re: LS-T t3/t04e turbo, sputtering problem when accelerating. Help!
Get it tuned.
I was having the same issue and it went away once the tune was done.
Old Jun 4, 2012 | 10:28 AM
kyden's Avatar
a basemap
Old Jun 4, 2012 | 11:00 AM
ef8sleepr's Avatar
thats what i want to hear. thanks guys! I mean my first turbo honda, it didn't sputter like this one. i guess it was a better basemap. i don't know. I got to go down to the tuner and see what he could find. also gapping on the ngk 7's, what are the common gapping specs for my setup? i bought the ngk7bkre11 the pre-gapped one. just wondering if that may cause an issue.
Old Jun 4, 2012 | 12:27 PM
kbouchard1092's Avatar
Yes that is a issue....Those are pre-gapped wayyyy to big i belive .044.. Even the regualr non-pre-gapped ones would be too big(.030)
You should take those plugs out right now and Gap them down to about .025ish. I have mine lower but for youre power levels. .024-.026 should be ok
As they sit right now you are definatly blowing the spark out with boost. Get it tuned, you shouldnt even be driving it till its tuned. Stay out of boost till then
Old Jun 4, 2012 | 03:08 PM
Arthas's Avatar
I had mine gapped to .025.
Old Jun 4, 2012 | 09:25 PM
ef8sleepr's Avatar
thanks guys. I now hooked the stock ecu and disconnected my ic piping so i won't hit boost. that shouldn't be a problem right? and def. thanks for the gap specs. .025 sounds much better. I really had .044 gap for a day. so I'll check em to see if they're ok. but i think mostly it's from the map.
Old Jun 5, 2012 | 06:43 AM
dpetro1's Avatar
you need to correct the CEL before getting tuned. what code are you getting?
rx7_
Aug 19, 2009 01:33 AM
CaptiveBlue92
Jun 22, 2008 10:21 AM
axxicution
Nov 24, 2007 07:45 PM
BoOsTiN Dc2
Nov 21, 2003 08:12 PM
TurboDC4
Feb 26, 2003 06:42 PM
