Clutch
Old May 29, 2012 | 06:15 PM
TravisBiggie's Avatar
Default Clutch
I found a exedy stage 2 locally for a damn good price (240 brand new)
I am seriously considering picking this up but I read 3 puck cluthes can damage your transmission?
If not, I am considering a CC stage 5 for 320 off of ebay.
Thoughts?
shooting for 300whp within the next two weeks, and 400+whp around summer.
exedy stage 2 is rated at 285ftlbs of torque, and the CC stage 5 is rated at 300% (390ftlbs) Would it be wise just to go with the CC stage 5?
One more question, hopefully yall read this. I have a 3" downpipe to 2 1/4 cat, then 2 1/4 cat back, will this be restrictive for 300whp? I am thinking so. If it is, I planned on buying a cut out, because my cat is 2 1/4 and so is my resonator.
Thanks
Old May 29, 2012 | 07:32 PM
Turbo-LS's Avatar
Default Re: Clutch
The exedy wont hold. Get the comp stage 5 and be done with it.
The exhaust is going to be very restrictive, you neer go from larger to smaller it bottle necks and kills performance. you would have better results with all the same size or smaller dp and larger exhaust. with turbo setup bets to have 2.5" minimum.
Old May 29, 2012 | 07:35 PM
TheShodan's Avatar
Moderator
Default Re: Clutch
yes it will. For the Exedy, you just have to get the right part number for the higher torque amount.. Exedy Part number 8950B. Takes over 400whp and 300ft/lbs of torque. And yes, I've done it with that clutch..
A Comp stage 5 is complete overkill and knock your teeth out.. Reasonable parts for reasonable goals.
Old May 29, 2012 | 08:13 PM
Default Re: Clutch
blah
Old May 29, 2012 | 08:24 PM
Gunmetal_B20_Hatch's Avatar
Default Re: Clutch
Comp stg.4 is a nice clutch also... Its available in a sprung disc.
Old May 29, 2012 | 09:10 PM
Dc4LsTeG's Avatar
EK9
Default Re: Clutch
This is what ill be using. Hoping for the best
Old May 29, 2012 | 09:26 PM
Turbo-LS's Avatar
Default Re: Clutch
For 400+ the stage 4 is great for street but for track abuse staff 5 is needed IMO
Old May 30, 2012 | 03:06 AM
blackeg's Avatar
Default Re: Clutch
Im using the comp stage 5 and its amazing. The disk itself hold up wayyyy better than the act stuff I used for years
Old May 30, 2012 | 03:35 AM
Axatax's Avatar
Default Re: Clutch
What would you recommend for a D16 with an otherwise stock S8G transmission w/MFactory LSD (189 HP @ 11 psi. on T3/T4 .63?, go-autoworks kit). I have a brand-new Exedy Stage 1 on 8 lb. flywheel and it slips at launch. Tires are Michelin MO1 185/65/14 (van tires) with less than 2K miles. Dyno tuned on AEM F/IC with P2E ECU.
Yes, I know this is odd-ball equipment but it's what I have to work with. Thanks!!
Old May 30, 2012 | 05:29 AM
Axatax's Avatar
Default Re: Clutch
Oh, and this is just a DD/street car.
Old May 30, 2012 | 06:58 AM
blackeg's Avatar
Default Re: Clutch
I drive my car to work 60 something miles on nice days with the st 5, it will be fine
Old May 30, 2012 | 07:38 AM
kyden's Avatar
Default Re: Clutch
i have a comp stage 5 (sprung). everyone that's driven the car has complimented on how smoothly the clutch engages.
Old May 30, 2012 | 08:57 AM
Turbo-LS's Avatar
Default Re: Clutch
I have the stage 5 unsprung. Doesn't feel any different than my friends stage 5 sprung both are comp clutches
Old May 30, 2012 | 09:01 AM
TheShodan's Avatar
Moderator
Default Re: Clutch
You're talking Drag strip right? We need to figure out if he's going more for street or drag strip with this.
Old May 30, 2012 | 01:39 PM
Default Re: Clutch
Street! couple times at the track a year. Mind you I have a lead foot 40% of the time
Old May 30, 2012 | 05:18 PM
Turbo-LS's Avatar
Default Re: Clutch
Yes sir i am refering to the drag strip, sorry i should be more clear in my posts, was doing that from my phone.
markjokeefe
Oct 4, 2008 12:25 PM
M1SCO15
12
Oct 25, 2006 09:47 AM
TSX TEX
Mar 19, 2006 09:32 PM
RAS Motorsports
Jul 14, 2004 05:15 AM
