Help with wastegate elbow
Old Jun 21, 2012 | 09:06 PM
B and B's Avatar
Loved
Community Favorite
Default Help with wastegate elbow
Bought this, cuz my Neukin ramhorn bought used (for a DC) places the wastegate where it hits core support. No elbow/extension on mani...maybe it worked on DC, but I have an EG, didn't want to beat my core support.
Like this..
Do I just clamp it to mani with no fire ring/sealing ring in the vband clamp? Cuz I cant fit a fire ring into the grooves since they're the same shallow grooves. The flange on the elbow is just like the outlet flange on mani...the rings I have all have the wider od, which sits in the flange..with a little extending, smaller od lip like this
only the wider od would fit into both flanges...is there such a flange/ring made? Inlet/outlet flanges all have two od's..it would have to be just a flat ring with the wider portion..no protruding smaller section
The site says for inlet side..so what to do?
http://www.atpturbo.com/mm5/merchant...egory_Code=WGT
Hope u guys have seen this before..ready to get my car going again, damn.
Seems like the sealing ring locates the parts inside the clamp? Is it common to not use a ring?
New to vbands..sorry
Damnit..calling ATP in the morn.
Old Jun 22, 2012 | 03:09 PM
B and B's Avatar
Loved
Community Favorite
Default Re: Help with wastegate elbow
ok, so no fire ring/flange needed when mating just the elbow...if it helps anyone later...
B and B
Welding / Fabrication
Jul 7, 2012 01:34 PM
gman105
May 17, 2010 07:39 AM
ProJectCvic
Jan 29, 2007 09:39 AM
94lsboost
Mar 29, 2005 05:31 PM
5STAR3
Jun 29, 2004 10:51 PM
