550cc + Crome + Turbo LS = No need FPR and Gauge??
well i was wondering why my tuner told me i would not need a FPR or gauge if i were to get tuned with my 550cc injecs on my stock LS. wondering why because my stock FPR 36psi is good enough already? juss wondering b/c i was thinkin about installin my FPR and buy a gauge but dunno if i really need it??
here is my air/fuel ratio
Modified by Jesse. at 11:30 AM 9/8/2006
Re: 550cc + Crome + Turbo LS = No need FPR and Gauge?? (Jesse.)
increasing the fuel pressure a tthe regulator increases the amount of power the injectors pull as the pressure is increased. Example if your injectors start running at like 95% at your current setup, you would just need to increase your fuel pressure to like 50psi and it would reduce the overall percentage to like 80 or 75%. I know the explanation is not great but this is the basic. You would def need a retune after this as you will be richer through out your power band and this was just an EXAMPLE OF THE THEORY.
i dont see why you would need a fpr with that setup. i could understand if the injectors were maxing out but 550's are not close to maxing out at your power level.
what fuel pump are you using?
Re: 550cc + Crome + Turbo LS = No need FPR and Gauge?? (dpetro1)
Walbro 255lph Fuel Pump
so i dont need to intsall my fpr and gauge? no need?
dont understand why my friedn who had a GSR tuned on crome with 550cc injecs near same setup as me did use a FPR and gauge and tuner used it to tune his car. but i didnt need one says my tuner ?
You certainly don't need any more than 36 psi pressure with 550cc injectors at your power level. An adjustable fpr and gauge would be a waste of money for you. Is the GSR simply making more power? Were there other issues with fuel delivery that the tuner had to compensate for?
Re: 550cc + Crome + Turbo LS = No need FPR and Gauge?? (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">You certainly don't need any more than 36 psi pressure with 550cc injectors at your power level. An adjustable fpr and gauge would be a waste of money for you. Is the GSR simply making more power? Were there other issues with fuel delivery that the tuner had to compensate for?</TD></TR></TABLE>
oic. yeah gsr was making more power like around 300+ at 9 psi?
At 300 whp and 45 psi of fuel pressure the duty cycle of the 550cc injectors would be right around 80%, the theoretical maximum safe level. The tuner probably raised the rail presure to 50 or so psi to keep it safe.
ITRfaithful
11-02-2003 06:15 PM
