Something different. Turbo LT1 swapped S10
Old 08-27-2006, 07:40 PM
CoreyR's Avatar
Default Something different. Turbo LT1 swapped S10
Not sure if this is the right forum so if it is mods can move it. thought some people would be interested to see this.
Its my friends 95 S10 thats hes been working on since high school (4+ years) he swapped an LT1 out of a 97 Z28 with an auto about 2 years ago. he did all the work himself and it was pretty quick did a 13.9@100 I/H/E in a heavy truck. this weekend we decided to throw a turbo kit on it to see what it would do. took us in the range of 25 hours to complete it. he plans to run 7 psi and tuning will be done on LT1 edit. he needs to upgrade his rear end because its going to launch axles if he puts too much power to it so therw wont be any sweet ripper vids for a few weeks. enjoy.
Modified by CoreyR at 4:40 AM 8/28/2006
Old 08-27-2006, 07:47 PM
CoreyR's Avatar
Default Re: Something different. Turbo LT1 swapped S10 (CoreyR)
some shitty digi cam vids. it was dark and wet unfortunatley.
http://www.we-todd-did-racing....5NTQx
StylishDOHC's Avatar
pretty cool remote mount...should be interesting
Old 08-27-2006, 09:57 PM
thehatchninja's Avatar
that's freakin awesome! I'm uncomfortable with remote mount turbos being under the vehicle, but in the truck bed is perfect. It looks so funny there, I love it.
Old 08-28-2006, 06:03 AM
* B A N N E D *
boosted94cx's Avatar
was it orignially a 4.3 truck or what? what mounts did he use? what drive shaft? was wiring hard? and what rear end do you upgrade with? 10 bolt or 12 bolt?
Old 08-28-2006, 06:40 AM
RyanEJ8's Avatar
Nice truck. They're honestly not that heavy for a truck though. I think my 00' S10 V6 is around 3200 lbs.
Old 08-28-2006, 06:54 AM
stockredej1's Avatar
Thats awesome
Old 08-28-2006, 07:01 AM
ATYPR's Avatar
Default Re: Something different. Turbo LT1 swapped S10 (stockredej1)
Are you guys using a pump on the return??
Old 08-28-2006, 07:24 AM
CoreyR's Avatar
Default Re: Something different. Turbo LT1 swapped S10 (FUCATYPR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FUCATYPR &raquo;</TD></TR><TR><TD CLASS="quote">Are you guys using a pump on the return??</TD></TR></TABLE>
tilton differential pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted94cx &raquo;</TD></TR><TR><TD CLASS="quote">was it orignially a 4.3 truck or what? what mounts did he use? what drive shaft? was wiring hard? and what rear end do you upgrade with? 10 bolt or 12 bolt?
yes 4.3. he made the mounts himself out of SBC mounts. stock shaft. hes ASE and GM certified, probably hard for someone who doesnt know everything about GM. stock 10 bolt which is why he cant drive it hard right now.
Old 08-28-2006, 07:52 AM
EJ1 wilcox's Avatar
I love the remote mount setup. Nice work putting it in the bed like that. At least that way the turbo won't be exposed to the elements like it would if it were under the bed like the STS setups.
Old 08-28-2006, 10:41 AM
ringgold's Avatar
Default Re: Something different. Turbo LT1 swapped S10 (EJ1 wilcox)
cool it would be awesome if he mounted all that stuff in one of those diamond plate tool boxes!!!
Old 08-28-2006, 11:39 AM
notoriousB's Avatar
Default Re: Something different. Turbo LT1 swapped S10 (ringgold)
that's a cool idea with the turbo in the bed. the bed in my s10 is already hacked due to the fuel cell... hmmmm... you're a bad influence! I've got no EFI in mine tho so management would be an issue unless I did a blow-thru carb setup.
is the turbo bolted to a brace or a mount of some sort? how's the oil return done? long gravity feed?
3200 lbs for an 00? my 82 is only 2200 lbs.
sweet truck!!
Old 08-28-2006, 12:47 PM
CoreyR's Avatar
Default Re: Something different. Turbo LT1 swapped S10 (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">that's a cool idea with the turbo in the bed. the bed in my s10 is already hacked due to the fuel cell... hmmmm... you're a bad influence! I've got no EFI in mine tho so management would be an issue unless I did a blow-thru carb setup.
sweet truck!! </TD></TR></TABLE>
yeah the turbo/flange has a mount we made it sits on top of it so the exhaust doesnt support it at all. its solid mounted to the bed. the oil return is run to a tilton differential pump under the bed. its the same pump nascar uses to pump the diff. fluid to a cooler for the rear end. it returns it to the valve cover.
Old 08-28-2006, 12:52 PM
Unceasing Measure
Archidictus's Avatar
Default Re: Something different. Turbo LT1 swapped S10 (RyanEJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanEJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Nice truck. They're honestly not that heavy for a truck though. I think my 00' S10 V6 is around 3200 lbs.</TD></TR></TABLE>
Yup. My 94 S10 was 31xx. They're significantly lighter than the F-bodies that engine comes out of
Old 08-28-2006, 01:04 PM
Snafubmx234's Avatar
Default Re: Something different. Turbo LT1 swapped S10 (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Yup. My 94 S10 was 31xx. They're significantly lighter than the F-bodies that engine comes out of </TD></TR></TABLE>
Eh, my buddy's LS1 Camaro weighs about 3400. Either way, it's still more fun to have less weight over the back tires.
Old 08-28-2006, 01:09 PM
HT White Ops
SD_Lurker's Avatar
Old 08-28-2006, 01:54 PM
15psi of fun's Avatar
Default Re: Something different. Turbo LT1 swapped S10 (nicks_jdmstyle_ef9)
you don't see that every day i like the set up
Old 10-14-2006, 02:21 PM
CoreyR's Avatar
Default Re: Something different. Turbo LT1 swapped S10 (15psi of fun)
justa little update, took the truck to the track this weekend. got the rear end all situated and it has some 245/40/18 BFG DR's. couldnt get any traction and there was some shifting issues, tranny doesnt shift fast enough and it pegs the limiter a couple times before it shifted.
best run was a 12.7@112 with a 2.195 60'. 7psi of boost and was shifting into OD because it doesnt have enough gear. it isnt tuned yet just runniing off the maf and 112 oct.
Old 10-14-2006, 05:46 PM
Blind-Fashion's Avatar
weak
Old 10-14-2006, 05:50 PM
CoreyR's Avatar
Default Re: (Blind-Fashion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind-Fashion &raquo;</TD></TR><TR><TD CLASS="quote">weak</TD></TR></TABLE>
haha i knew that was comming
Old 10-14-2006, 06:07 PM
Default Re: (CoreyR)
112 mph is really fast tho, i mean REALLY fast, like reaLLY reALLY REALLY faster. like almost super faster.
Old 10-15-2006, 05:21 AM
2point2's Avatar
My good friend did the same swap. It's a lot of work!
it was a allmotor "400hp" engine with very lumpy cams lol.. the whole truck twitched as it idled.
You could make a lot of jaws drop around town with that truck. mid/high 12 is awesome for a truck.
Old 10-15-2006, 06:48 AM
93supercoupe's Avatar
Default Re: (2point2)
tuned on more boost would put that bitch in the 11's
thats BALLIN!!!
Old 10-15-2006, 09:00 AM
sikciv666's Avatar
Default Re: (93supercoupe)
that **** is sick......
Old 10-15-2006, 11:15 AM
I've quit using this account
Kelly.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">tuned on more boost would put that bitch in the 11's
thats BALLIN!!! </TD></TR></TABLE>
all he needs is traction and hes there.
how do the LT1s handle boost?
im looking to do one (in a f body though)
Quick Reply: Something different. Turbo LT1 swapped S10
