Problem with wastegate/radiator
Old Aug 29, 2006 | 10:57 AM
RH-DTeg's Avatar
Default Problem with wastegate/radiator
Well first off i have a '99 GSR Teg, Im in the process of fitting all my turbo parts. I have the ssautochrome stuff. The only problem i have is that the radiator is in the way of the wastgate, i was wanting to know if a civic radiator would work? i was thinking of putting the civicrad on the right side, would that still give effecient cooling? By the way i tryed searching, didnt work.
Old Aug 29, 2006 | 11:04 AM
Speed Infliction's Avatar
Default Re: Problem with wastegate/radiator (RH-DTeg)
yes use the civic radiator and put it on the passanger side.
Old Aug 29, 2006 | 11:54 AM
RH-DTeg's Avatar
what do i do with my hoses, will they work?
Old Aug 29, 2006 | 12:50 PM
speedlabx2005's Avatar
Default Re: (RH-DTeg)
your gonna need civic radiator hoses and then use the stove and heat up the other side of the hose so it can fit your B series thermostat housing. i would take off the thermostat housing and then heat up that hose much easier
Old Aug 29, 2006 | 02:41 PM
kameleon23's Avatar
Default Re: Problem with wastegate/radiator (Speed Infliction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Infliction &raquo;</TD></TR><TR><TD CLASS="quote">yes use the civic radiator and put it on the passanger side.</TD></TR></TABLE>
After that is solved, i would seriously think about bracing that ssac...or then you will be having a bigger problem than you do now
Old Aug 29, 2006 | 04:29 PM
RH-DTeg's Avatar
yea i heard about that, i have the new design which has braces.
Old Sep 8, 2006 | 06:37 AM
RH-DTeg's Avatar
Default Re: (speedlabx2005)
i understand that, but i was going to use the civic hoses but theres no way the top hose will go over to the right side, plus the bottom hose is way to close to the header. I was also wanting to make this as clean as possible.... any ideas?
Sprockets
Feb 19, 2017 08:04 PM
mrlegoman
Jan 14, 2006 01:01 PM
ATS*Mark
Jul 19, 2004 03:02 PM
revhigh89
Jan 21, 2004 02:10 PM
Flamenco-T
Feb 25, 2003 12:53 PM
