OVERBORED CYLINDER!!!
Old Aug 29, 2006 | 07:36 AM
peakboosth22's Avatar
Default OVERBORED CYLINDER!!!
Well, i just bought a build h22 short block and i've realized that three of the cylinders are bored over .0040, which i knew about, but one of the cylinder is bored over .0051!!! Now, my tuner, who is putting in the engine, told me that the cons of this mistake is that:
1.) AT start up, the engine will make some noise> I have to wait for the engine to warm. He told me once the motor heats up, the metals will expand and eliminate the .0011 difference in that one cylinder.
IT MAKES SENSE, BUT IS SAFE OR WILL THE MOTOR GIVE UP ON ME IN TWO MONTHS
Modified by peakboosth22 at 1:19 PM 8/29/2006
Old Aug 29, 2006 | 07:43 AM
tony1's Avatar
Default Re: OVERBORED CYLINDER!!! (peakboosth22)
So your tuner says it's ok to have .010" extra piston to wall clearance in 1 hole?
Old Aug 29, 2006 | 08:01 AM
Default Re: OVERBORED CYLINDER!!! (tony1)
hE SAID that it is definitly not ideal or recommended, but he said that it should be o.k
Old Aug 29, 2006 | 08:06 AM
tony1's Avatar
Well what's the piston to wall clearance on the rest of the holes? What pistons?
Old Aug 29, 2006 | 08:19 AM
Finland's Avatar
wtf, 10 thou is way too much, expansion will not make up the difference.
Old Aug 29, 2006 | 08:34 AM
im not sure about the clearence, but the pistons are .40 over arias pistons with 9:2 compression ratio
Old Aug 29, 2006 | 08:45 AM
Sir-g Turbo's Avatar
ask ur tuner how he plans on building compression in a sleeve thats .50 over and a slug thats .40 over? blowby anyone? mass oil consumption perhaps? n/a ur rings will b in danger and they dont stand a chance against boost. just lookin out man, i dont want ur pride and joy to give out a couple months down the road. just my $0.02
Old Aug 29, 2006 | 08:50 AM
tony1's Avatar
Default Re: OVERBORED CYLINDER!!! (Sir-g Turbo)
Basically, it's a very bad idea, don't do it...
Old Aug 29, 2006 | 08:52 AM
to tony1 for the backup
Old Aug 29, 2006 | 08:54 AM
rice a roni's Avatar
um..who bored it for you? thats messed up shop work man..get ur money back...
no dont run it like that. get them bored out the same and get new overbored pistons.
Old Aug 29, 2006 | 09:56 AM
PrecisionH23a's Avatar
I had a kid with a build D series come in for a tune one time. I did a compression test prior the tune and cylinder 3 read 30psi or 40psi lower for some reason than the other cylinders if I remember correctly.
Anyways, I tuned the engine and on top of the other 10 problems the car had it did so-so on the dyno. The engine then spun a bearing about 6 weeks afterwards then he had me come over to inspect the block. Immediately I looked at the number 3 cylinder and for some reason the piston looked funny. It turned out he was running a stock bore piston in a 20 over wall in cylinder 3. He failed to mention to me prior that he dropped a single piston on the install and had to order a new one. He ordered the wrong one and didn't notice it upon assembly, lol.
So yea it will run... but it's probably the dumbest thing you can do.
Old Aug 29, 2006 | 10:50 AM
Default Re: OVERBORED CYLINDER!!! (PrecisionH23a)
SOOOORRRY guys!!!!
That one cylinder has been over to .0052 as comared to the other three cylinders, which are at .004
Now, will this contrast cause a problem or will the engine be o.k
Old Aug 29, 2006 | 12:00 PM
SOHCD16y8's Avatar
All around it is just a terrible idea and more then likely you will have major oil consumption. WHy would you even take the time to put a motor together you know is not right? I would take it back to whereever you got it machined or bought it from and get your money back and start with a fresh block. .012 is even worse the the .010 in the original post.
Old Aug 29, 2006 | 12:08 PM
Default Re: (SOHCD16y8)
no, it's not the difference is not .012. Its .0012
Old Aug 29, 2006 | 12:25 PM
SOHCD16y8's Avatar
Im pretty dure that you added one to many zeros in there, Cylinders are usually bored in .010 increments. I dont even think they sell pistons in .0040 oversizes.
Old Aug 29, 2006 | 12:40 PM
Default Re: (peakboosth22)
I'm not trying to be a ********... but you really need to have someone who knows what they are doing assemble your engine. Seriously, your machinest/builder is having you scour the internet for info that he should already know. I doubt he is even going to check your ring end gap, bearing clearances, etc.
h2.4
19
Feb 19, 2010 09:39 AM
downeyballz
Jul 6, 2008 01:21 PM
Nisif
Mar 6, 2005 03:36 PM
seako_916
May 19, 2004 09:28 PM
seako_916
May 19, 2004 08:52 PM
