How heavy should a dumptube BE? i got mines done at muffler shop too heavy??
so i got my revhard elbow wielded with some metal or something and made it a dumptube at a muffler shop. only cost me like 20 bucks.. but then my Deltawastegate one of the bolts came loose. wondering was it because my dumptube too heavy? was it made out of wrong material? or was it just my wastegate bolt was loose.. my dumptube is about 4-6 pounds (heavier then it looks)?? how heavy are ur dump tubes.. wndering if mine is too heavy and made of wrong material or something.. runnin on a revhard manifold..
Modified by Jesse. at 3:40 PM 8/26/2006
Re: How heavy should a dumptube BE? i got mines done at muffler shop too heavy?? (Jesse.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">That weld looks a little heavy. Go back and have them make it out of titanium.</TD></TR></TABLE>
ic.. so if it was too heavy it would be causing my wastegate to get loose?
Re: How heavy should a dumptube BE? i got mines done at muffler shop too heavy?? (Muckman)
lolllll
lolllll
Re: How heavy should a dumptube BE? i got mines done at muffler shop too heavy?? (1Quikgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Quikgsr »</TD></TR><TR><TD CLASS="quote">lolllll </TD></TR></TABLE>
seriously... titanium dump tube.. o wow. thats money.. stop jokin around and help me out..
Lol.Just go get some lock washers/loctite etc so they dont rattle out.
Re: (importdude2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 »</TD></TR><TR><TD CLASS="quote">cut all that pipe off
and get a felixable exhuast pipe/hose at autozone for 5 bucks
if u want it lighter</TD></TR></TABLE>
ic.. will that be able to handle the hot air coming out of my wastegate?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgmatt »</TD></TR><TR><TD CLASS="quote">Lol.Just go get some lock washers/loctite etc so they dont rattle out.</TD></TR></TABLE>
lock washers on my wastegate? they are used. on my wastegate and my down pipe.
Re: (Jesse.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesse. »</TD></TR><TR><TD CLASS="quote">
lock washers on my wastegate? they are used. on my wastegate and my down pipe.</TD></TR></TABLE>
use longer bolts that screw into Tial ull see extra trheads behind the tial flange
then add locknut there too
cut it after the bend +3-4 inches down
of course it will
of course it will
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 »</TD></TR><TR><TD CLASS="quote">use longer bolts that screw into Tial ull see extra trheads behind the tial flange
of course it will</TD></TR></TABLE>
too bad i can only afford a Deltawastegate =\ i cant use longer bolts and use nuts/washers on other side cause thats going into my turbo manifold.
I want a CRX tattoed on my butt
Re: (Snafubmx234)
I guarantfuckingtee that is less than 2lbs
Theres no way that thing weighs 6lbs, thats a standard thickness flange with regular shitty pipe, thats what everyone has
Just bolt it back up with a lockwasher nice and tight and it should never go anywhere
too bad i can only afford a Deltawastegate =\ i cant use longer bolts and use nuts/washers on other side cause thats going into my turbo manifold.</TD></TR></TABLE>
does it?
does it?
Re: How heavy should a dumptube BE? i got mines done at muffler shop too heavy?? (importdude2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS »</TD></TR><TR><TD CLASS="quote">I guarantfuckingtee that is less than 2lbs
Just bolt it back up with a lockwasher nice and tight and it should never go anywhere</TD></TR></TABLE>
yeah its around 2-3 pounds. maybe 3.5 the MOST. sorry im bad at judging weight, but i just held some weights on left hand and right hand and yeah..
Just bolt her up, if you dont plan on changing piping/setups for a while throw some loctite on there, guaranteed to never come undone, but when you want them to come undone...... hard as expletive
Re: How heavy should a dumptube BE? i got mines done at muffler shop too heavy?? (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX »</TD></TR><TR><TD CLASS="quote">Reason its heavy is cause ur using a cast 90 deg.
Go to ur stores get a piece of 1/8" steel 3/4" wide and make a braket man</TD></TR></TABLE>
make a bracket to hold the dumptube?
no way wtf, its a mild steel 90*
Just ******* bolt it up tight with a lock washer and loctite
Dont even ******* think about anything else
make a bracket to hold the dumptube?</TD></TR></TABLE>
no, to hold your wee wee while you pee!
the 90 is probably the heaviest piece of metal in that dumptube. either go with the above and make a bracket, for it, or i say cut that 90 in half and get the bendable flex pipe from checker or wherever and just clamp that on there. Bend, be happy, and light, and FAH-GET'A 'BOUTiT!
Re: (igo4bmx)
AhAHAHAHahAH ok ill juss slapp that b!tch on and call it a day. and then ill juss look at my wg once in awehil to make sure both bolts are on.
Re: (Jesse.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">i think u need to workout more man</TD></TR></TABLE>
ahaha i juss thought it might be too heavy b/c recently just did a motor swap and was holding the charge pipe and it felt like diff material.. very much ligther .
