cam not spindont spin, so how bad of a problem is this. ning
Old 08-30-2006, 04:10 PM
mra4886's Avatar
Default cam not spinning
ok i am looking at a car to buy and it has a very nice setup on it, but one of the cams stop spinning, so how bad of a problem is this.
Old 08-30-2006, 04:17 PM
SOHCD16y8's Avatar
That is a pretty major problem, most likely it snapped the timing belt, the motor fell out of time and piston valve contact occured. The motor is most likely toast.
Old 08-30-2006, 04:20 PM
mra4886's Avatar
Default Re: (SOHCD16y8)
no the timming belt is still intact, he said it was due to installing the cam seals wrong and tighting the bolts to tight it popped the seals out and it was metal rubbing agaist metal.
Old 08-30-2006, 04:24 PM
BlackT5's Avatar
yea that's bad
Old 08-30-2006, 04:28 PM
mra4886's Avatar
Default Re: (BlackT5)
he said he talked to some people and it just needs new cams.
Old 08-30-2006, 04:35 PM
New User
01geeser's Avatar
Default Re: (mra4886)
i doubt you just need new cams.....you prolly have head damage. if the motor actually ran with this cam not spinning you prolly have piston valve contact too.
SOHCD16y8's Avatar
You realize it is pretty much impossible for the timing belt to be intact with only one cam spinning. And if you already have all the answers then why did you make this post.
Old 08-31-2006, 05:57 PM
mra4886's Avatar
well the timing belt is still intact cause it happened at idle and it was shut down.
Old 08-31-2006, 06:37 PM
NJIN BUILDR's Avatar
So the guy selling the car says its OK.I can't think of any reason he would mislead you......
Anyway the head and valves are more than likely tashed.
Old 08-31-2006, 06:41 PM
SOHCD16y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mra4886 &raquo;</TD></TR><TR><TD CLASS="quote">well the timing belt is still intact cause it happened at idle and it was shut down.
So he is telling you that he was idling the car and a cam stopped so he shut it down before anything could happen. Even at idle the cam is still rotating 6 times per second. There is no way it would make it out timing belt intact. Sounds lke he is lying to you to get the motor off his hands.
Old 08-31-2006, 07:36 PM
Hondoctors's Avatar
Don't buy it, not worth the trouble, and you'll probablly need a new head at the very least.
Old 09-01-2006, 12:20 PM
mra4886's Avatar
Default Re: (Hondoctors)
im not getting it hes being a dick on the price, so i was just trying to get the shell and the b16 tranny but hes still being a dick on the price. so i tried just for the shell and still nothing he wants 1k for the shell. and its not worth it. he wont give me a price on shell and tranny. so im not getting it.
jayupark
12-21-2013 12:22 PM
hellaflushdb2
08-06-2013 09:10 PM
92EG8
11-02-2008 03:41 AM
Racermech
06-25-2006 04:33 PM
misterpsycho
04-13-2006 10:31 AM
Quick Reply: cam not spindont spin, so how bad of a problem is this. ning
