d16y8 block w/ z6 head Nitrous build
Old 08-28-2006, 11:10 AM
SFlCrx's Avatar
Default d16y8 block w/ z6 head Nitrous build
well just picked up a y8 block last week from a friend and i just honed it and did some measuring. Anyways i wanted to do a nitrous build did some research but did not really find what i was looking for most of the search results where nitrous questions and noobish ****. i know how nitrous works and what is need for it to keep my engine safe.
heres my list of parts that i have or going to be getting
Engine- D16y8 block w/ D16z6 head in a crx
Forged pistons w/ rods (9.1 or 10.1 compression ratio pistons don't know yet taking suggestions)
crower stage 2 cam
vavle springs and titanium retaniers
y8 or skunk 2 manifold
adjustable FPR
all ARP hardware
100-125 zex wet kit
I/H/E
stage 2 clutch w/ lightweight flywheel
walbro 255 pump
colder plugs gapped at .028
looking for about 170-185 whp and 170 torque on the bottle and about 130-140 whp 120 torque off the bottle .
any suggestions is greatly apprieceated
Modified by SFlCrx at 5:41 PM 8/30/2006
Old 08-28-2006, 04:07 PM
northkai3's Avatar
Default Re: d16y8 block w/ z6 head Nitrous build (SFlCrx)
yes im am curious 2
Old 08-28-2006, 04:58 PM
85's Avatar
Default Re: d16y8 block w/ z6 head Nitrous build (northkai3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by northkai3 &raquo;</TD></TR><TR><TD CLASS="quote">yes im am curious 2</TD></TR></TABLE>
there was a post on here about a year ago with a guy running 200shot on an LS. funny thing was, he was running (if i remember correctly) either 11 or 12:1 CR. never had any probs. his outlook on it was that wail using so much N2O it cooled everything down to keep it from blowing up.
Old 08-28-2006, 06:05 PM
cubish's Avatar
if you plan on making good power and taking advantage of running higher lift cams i would go higher on the compression. on street motor i run 11 to 1- 11.5 to 1 and over 14 to 1 on my race motors
Old 08-28-2006, 06:40 PM
SFlCrx's Avatar
its not going to be a race car its going to be a weekend car What about my set up ? i did a lot of research, am i forgetting something or do guys think all the mods would work well. thanks
Old 08-28-2006, 06:44 PM
cubish's Avatar
Default Re: (SFlCrx)
like i said.. on my street motors i run a little over 11 to 1 compression. youre cutting your self short running anything near 9 or 10 to 1. everything else seems pretty good. i'd get a nice header, b series throttle body, and a block gaurd
Old 08-28-2006, 06:46 PM
SFlCrx's Avatar
Default Re: d16y8 block w/ z6 head Nitrous build (hks85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hks85 &raquo;</TD></TR><TR><TD CLASS="quote">
there was a post on here about a year ago with a guy running 200shot on an LS. funny thing was, he was running (if i remember correctly) either 11 or 12:1 CR. never had any probs. his outlook on it was that wail using so much N2O it cooled everything down to keep it from blowing up. </TD></TR></TABLE>
i'm not worried about things melting, i'm worried about the nitrous shooting my compression ratio way too high for the engine thats why i was opting for a lower compression ratio piston. From my knowledge nitrous will up the compression right?
Old 08-28-2006, 06:51 PM
SFlCrx's Avatar
Default Re: (cubish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cubish &raquo;</TD></TR><TR><TD CLASS="quote">like i said.. on my street motors i run a little over 11 to 1 compression. youre cutting your self short running anything near 9 or 10 to 1. everything else seems pretty good. i'd get a nice header, b series throttle body, and a block gaurd</TD></TR></TABLE>
Any suggestions for header and block gaurd? thinking Kteller for the header and 2 1/4 straights to apexi N1
Old 08-29-2006, 10:22 AM
SFlCrx's Avatar
any more input?
Old 08-29-2006, 11:57 AM
i ♥ snails
quicksilver1689's Avatar
Direct port, whats good for allmotor performance usually compliements nitrous very well. 10-11.5:1 compression is what i reccomend depending on fuel octane, timing, ect. Freeflowing intake, intake mani, and good header will help. You can get various jets too see what your motor likes. I think cubish could tell u more about it. Some motors like too run slightly fat on the fuel side some dont respond as well i think its just a trial and error kinda deal when it comes to the fuel and nitrous jet ratios. Good luck
Old 08-29-2006, 06:22 PM
cubish's Avatar
Default Re: (quicksilver1689)
the power levels you are looking for are very easy to get. figure if you can make anywhere from 120-140 all motor it wont take much to make over 200 on spray. stock b series motors with bolt ons usually make around 280-290 on spray after i tune them.. my built setups have made anywhere from 330-500 on spray. i think you could make around 220 or so safely on pump gas with what you have planned..
Old 08-30-2006, 03:58 PM
SFlCrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">Direct port, whats good for allmotor performance usually compliements nitrous very well. 10-11.5:1 compression is what i reccomend depending on fuel octane, timing, ect. Freeflowing intake, intake mani, and good header will help. You can get various jets too see what your motor likes. I think cubish could tell u more about it. Some motors like too run slightly fat on the fuel side some dont respond as well i think its just a trial and error kinda deal when it comes to the fuel and nitrous jet ratios. Good luck </TD></TR></TABLE>
Fuel will be 93 of course timming will 4 degree retarded for the nitrous. As for intakes AEM V2 and either y8 or skunk2 manifold. i keep the Air/fuel at around 11 to 1 on the bottle and 12.5 to 1 off the bottle with chrome
Old 08-30-2006, 04:02 PM
SFlCrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cubish &raquo;</TD></TR><TR><TD CLASS="quote">the power levels you are looking for are very easy to get. figure if you can make anywhere from 120-140 all motor it wont take much to make over 200 on spray. stock b series motors with bolt ons usually make around 280-290 on spray after i tune them.. my built setups have made anywhere from 330-500 on spray. i think you could make around 220 or so safely on pump gas with what you have planned..</TD></TR></TABLE>
Thanks for the help and what do you recommend as far as block gaurds? do you think i will need one and any suggestions of where to get one?
Old 08-30-2006, 04:33 PM
cubish's Avatar
i wouldnt rely on just the a/f ratio when tuning the nitrous.. nitrous tends to throw off the afr reading a lot of time..block gaurd wise you can use a golden eagle..str..race engineering..chm.. they all pretty much do the same thing.. should be around $100
Old 08-30-2006, 04:40 PM
SFlCrx's Avatar
thanks alot. what cam do you use in your builds? oh yea hows the tropical storm i should be getting it soon up here in orlando
Old 08-30-2006, 05:35 PM
cubish's Avatar
the storm was weak.. i usually run some pretty big cams..ive ran everything pretty much... ctr, skunk 2's and 3's.. buddy club 3's and 4's.. they all worked good for me..
Old 08-30-2006, 05:46 PM
SFlCrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cubish &raquo;</TD></TR><TR><TD CLASS="quote">the storm was weak.. i usually run some pretty big cams..ive ran everything pretty much... ctr, skunk 2's and 3's.. buddy club 3's and 4's.. they all worked good for me..</TD></TR></TABLE>
oh yea i forgot you build b seris not d series just want to know if the crower stage 2 would be good people have been saying good things about the zex cam too don't know what i want yet
Kevin Detres
10-21-2013 02:59 AM
ww3slayer
08-17-2010 10:26 PM
j0keefe21
31
11-13-2009 11:49 PM
brusk13
06-20-2005 09:25 PM
goshblamit
06-09-2004 06:54 AM
Quick Reply: d16y8 block w/ z6 head Nitrous build
