GT42R, AC, 4" downpipe, need I say anymore?
1 Post
Well, here are the manifold pictures. Ive had three weddings to attend to this weekend so not as much time as I wouldve hoped. Tomorrow Ill start and finish the downpipe.
Wednesday Ill finish the WAIC.
End user will have to change inlet/outlet on the radiator, I can do it here in 30 minutes. Everything else is pretty much retainable except radiator fans, which with the WAIC setup, pusher fans are a breeze.
I think its pretty cool, never seen it done on a FWD Honda before
HELLO,GOOD MORNIN'
Re: (redzcstandardhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondoctors »</TD></TR><TR><TD CLASS="quote">Wow, nice manfold. What do you plan to do with the oil return for the turbo?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">how are you doing the charge piping?? Water to Air IC is about the only way i can doing it.....more PICS!!</TD></TR></TABLE>
that's what i want to see. and what kind of braces do you have for the manifold.
something different
1 Post
Re: (null.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by null. »</TD></TR><TR><TD CLASS="quote">upper radiator hose looks like it's going to get cooked! </TD></TR></TABLE>
he talked about that in the original post. it needs to be modified.
1 Post
Re: (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T »</TD></TR><TR><TD CLASS="quote">
that's what i want to see. and what kind of braces do you have for the manifold.</TD></TR></TABLE>
Yes, WAIC, as posted in my first post; you can see the core there...
Ill have a heim joint bracing system figured out; similar to this:
Naturally, to the transmission somewhere.
Oil return; thats up to the end user, but there are a few windows that can be used; along with a lot of firesleeve!
Re: (Tinker219)
that is amazing work but i dont see it being worth all the extra work when you can just get a FR top mount. I see its more for the racer than driver.
Unceasing Measure
Re: (fknfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fknfast »</TD></TR><TR><TD CLASS="quote">that is amazing work but i dont see it being worth all the extra work when you can just get a FR top mount. I see its more for the racer than driver.</TD></TR></TABLE>
Does the FR topmount allow for air conditioning, a GT42R sized turbo and a full 4-inch downpipe? Yeah, I didn't think so.
Re: (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">how much HP r u gonna get from this turbo?</TD></TR></TABLE>
Nobody has ever been able to successfully dyno with one of these turbos due to the fact that any baby within 300 feet will promptly be sucked into its inlet
Re: (SOHCD16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCD16y8 »</TD></TR><TR><TD CLASS="quote">
Nobody has ever been able to successfully dyno with one of these turbos due to the fact that any baby within 300 feet will promptly be sucked into its inlet</TD></TR></TABLE>
lol i like that....its going in my sig...thats so damn true though!
1 Post
Re: GT42R, AC, 4" downpipe, need I say anymore? (Tinker219)
Well, the WAIC location was just shot to ****; damn RHD conversions. So the car will be here before winter for some sort of WAIC solution.
Here are the downpipe pictures.
Customer's motor is built for 1200hp; I think he will dyno queen it as high as his gonads will let him, then he will turn it down and run on pump gas, 500whp-ish.
Re: (fknfast)
Where the expletive do u see FR top mount with ac?
People like u kill me, ignorance at its best. Why the expletive bring another manufactor into this thread?
I never see u post anything informational.
Looks good cody.
On the mount, it really needs to hang from the heim to be effective in allowing the manifold to expand, but not support the weight of the turbo.
Good luck with that intercooler. Why not run the charge piping down and do a big vertical flow intercooler with the inlet and outlet on the pass. side, then you can run the ic piping up behind the headlight to the t/b. Air/air is a much better setup for the street anyways.
1 Post
Re: GT42R, AC, 4" downpipe, need I say anymore? (tony1)
Thanks Tony; the way the heim joints will be designed, expansion and contraction shouldnt be an issue, as they will allow pivoting in the proper directions, and proper weight suppor. I do realize hanging heims are the best, but are also very difficult to properly package(especially when the turbos are 1/2" from the hood).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 »</TD></TR><TR><TD CLASS="quote">Thanks Tony; the way the heim joints will be designed, expansion and contraction shouldnt be an issue, as they will allow pivoting in the proper directions, and proper weight suppor. I do realize hanging heims are the best, but are also very difficult to properly package(especially when the turbos are 1/2" from the hood).
True, but the pic clearly shows the turbo isn't 1/2" from the hood. The distributor is quite a bit higher than the turbo. There's plenty of room to hang it.
