waste gate not opening?
Old Aug 27, 2006 | 01:35 PM
w0ng_sta's Avatar
Default waste gate not opening?
so again.. i have a tial 38 mill wastegate with a .4 bar spring and i just connected a vaccum hose from the side port to a T in my brake booster vaccum line. I will be connecting it to my charge pipe at some point but i cant do ti now im on a very strict time constraint =[.. but in anycase i also don thave a boostgauge yet and from what i can tell the wastegate isnt opening.. could it just be stuck? or um... stuck?
any help would be nice thanks
Old Aug 27, 2006 | 07:59 PM
w0ng_sta's Avatar
Default Re: waste gate not opening? (w0ng_sta)
n e one??
Old Aug 27, 2006 | 08:10 PM
CoreyR's Avatar
so you have no boost gauge but you assume its not opening? what makes you think that?
Old Aug 27, 2006 | 08:12 PM
Civicman86's Avatar
if your wastegate is not opening and your have made a full rpm pull then your motor would be dead (no wastegate= infinite boost).
Old Aug 28, 2006 | 05:34 AM
w0ng_sta's Avatar
Default Re: (Civicman86)
well of course i dont do full rpm pulls.. without boostgauge thats just retarded.. but i figure i would hear the wastegate open if it was opening.. its only a .4bar spring.. should open rather quickly.. also i took the dumptube off and it still looks pretty clean in the wastegate flange.. if it were opening it would be covered in **** no?
Old Aug 28, 2006 | 10:52 AM
SOHCD16y8's Avatar
You didnt tee after the check valve in the brake booster line correct. That could be your problem right there. Wastegates generally dont get stuck, they are so simple it would take a lot for it to mess up. Get a boost gauge and see whats really going on.
Old Aug 28, 2006 | 11:19 AM
swappedcx's Avatar
Default Re: (SOHCD16y8)
i dont know about your problem, but if you want a .7bar spring ill trade you for that .4
Old Aug 28, 2006 | 11:27 AM
eg crunkmonster's Avatar
Default Re: (swappedcx)
i dont thinku have ur wastegate connected correctly, the vaccum hose should run from the turbo to the bottom port of the wastegate and the top port on the wastegate should be left open unless u are running a boost controller
Old Aug 28, 2006 | 12:13 PM
dpetro1's Avatar
Default Re: (eg crunkmonster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg crunkmonster &raquo;</TD></TR><TR><TD CLASS="quote">i dont thinku have ur wastegate connected correctly, the vaccum hose should run from the turbo to the bottom port of the wastegate and the top port on the wastegate should be left open unless u are running a boost controller</TD></TR></TABLE>
well really the side port can get any pressure source. and the top port is only used on electronic boost controllers.
this guy needs to grab a boost gauge before anything else. you pretty much have to go WOT to build boost. are you hearing the turbo spool up? are you sure you are even getting into boost? a boost gauge can tell you whats going on and then you can go from there.
Old Aug 29, 2006 | 12:36 AM
w0ng_sta's Avatar
Default Re: (dpetro1)
heh thanks guys.. i fixed it..
Old Aug 29, 2006 | 07:31 AM
dpetro1's Avatar
Default Re: (w0ng_sta)
what ended up being the problem?
flangemastermike
Jun 13, 2007 04:46 AM
TurbodTegSfaria
Oct 14, 2006 07:28 AM
Nextelbuddy
Oct 13, 2003 08:14 PM
ebp 99 si
Jun 15, 2003 07:45 PM
1tyme
Apr 6, 2003 05:47 PM
