Turbo elements top mount manifold!
Old Aug 31, 2006 | 07:36 PM
tagperformance's Avatar
Default Turbo elements top mount manifold!
Has anyone had experience with this manifold?? they are priced pretty good!.
Old Aug 31, 2006 | 07:38 PM
Hondoctors's Avatar
Kelly got one, and you know he made big power with it on the SOHC... I think it's good looking, and the price is great.
Old Sep 1, 2006 | 05:00 AM
IHaveTurbos's Avatar
Jarrod, Thanks for the post.
Dion, if you have any question feel free to hit me up and I will get you the answers your looking for.
Here is a GT4088R Setup for good measure.
Old Sep 1, 2006 | 05:10 AM
planeman01's Avatar
i just wet ma'self
Old Sep 1, 2006 | 06:28 AM
Topdawgg's Avatar
WOW
Old Sep 1, 2006 | 06:52 AM
quicksilver1689's Avatar
i ♥ snails
Damn thats a sexy setup. love the dual wastegates
Old Sep 1, 2006 | 08:18 AM
turbotime's Avatar
whoa
Old Sep 1, 2006 | 08:19 AM
OneWickedef2's Avatar
oh meng...(jaws juss hit the floor..
Old Sep 1, 2006 | 11:19 AM
Thanks for the words everyone, there will be pics of it installed and a dyno of that setup in the next 2-3 days.
I will let the owner post if he chooses.
Old Sep 1, 2006 | 11:37 AM
black cx's Avatar
Default Re: (TurboElements.com)
manifold looks crazy
Old Sep 1, 2006 | 12:15 PM
uglyasscivic's Avatar
Default Re: (black cx)
Looks very nice. Do you have a pics of the runners and cylinder pairing?
Old Sep 1, 2006 | 12:36 PM
Cortney, I will shoot you some pics.
Old Sep 1, 2006 | 12:38 PM
The Destroyer's Avatar
Wow, these are beautiful. Not a bad price on the website either.
Old Sep 1, 2006 | 12:39 PM
TurboJesse
Guest
Posts: n/a
looks great Tim
Dumptubes going under the pan look sick like that.
Old Sep 1, 2006 | 12:40 PM
Thanks Jesse. I want to see what happens when you know what is posted.
Old Sep 1, 2006 | 01:00 PM
RedEj8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboElements.com &raquo;</TD></TR><TR><TD CLASS="quote">Here is a GT4088R Setup for good measure.
New "Wack-It" material for me.
Old Sep 1, 2006 | 01:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboElements.com &raquo;</TD></TR><TR><TD CLASS="quote">Cortney, I will shoot you some pics.</TD></TR></TABLE>
Old Sep 1, 2006 | 02:24 PM
Han Solo's Avatar
Default Re: (uglyasscivic)
is this mani equal length???
Old Sep 1, 2006 | 02:27 PM
It isn't 100% equal length, but close.
The manifold has already been proven to make power, the same design made 441hp and 333ft lbs on a SOHC with a 57 trim @ 25psi.
Old Sep 1, 2006 | 11:22 PM
I'd love to see what kind of power it would make with a 67mm turbo on a 2L vtec motor!.
Old Sep 2, 2006 | 01:32 AM
smutmonger's Avatar
that makes daddys special parts tingle!
Old Sep 6, 2006 | 09:17 AM
servion's Avatar
Default Re: Turbo elements top mount manifold! (tagperformance)
Well, I finally got to tune this thing. After tuning Kelly's 441whp SOHC with this topmount, I was impressed and I ended up talking with Tim about it. He built this divided, twin 44 gate topmount setup.... and it is beautiful. Fitment is excellent and quality is top notch. Downpipe and dumptubes routing is great, the ground clearance is maximized, I have no problems driving it with a full 4" exhaust and 12" flex tube with both wastegate dumps on the street. (As a mattter of fact, I am driving it 80 miles to the drag strip today ) Tim made the transition to a topmount setup very easy, his customer service is top notch. I was in a pinch for time and Tim came through. I am very happy with the setup.
Here are a few pics:
I am having a boost-tapering issue... I made 405whp uncorrected on 12psi absolute (1-bar spring but we are at 6500 feet elevation so there is a ~3psi difference between absolute boost pressure and gauge boost pressure). Once the boost gets up there, I can't seem to keep it from tapering off. The old-school profec-b (spec 1) wouldn't let me get over 25psi gauge, so I borrowed a manual controller to get what you see above. If you look a tthe last graph, it has a plot showing gauge boost pressure. Subtract 3psi from those pressures to see what the absolute boost pressure was (i.e. what the map sensor and motor are seeing). I am losing 5psi from peak boost to redline, so I am looking at an AMS1000 to try and correct the issue.
The setup is:
Benson 83mm GSR, LS crank, full-race rods ( ), CP pistons
Stock GSR head with supertech valves, springs and retainers, ITR cams
GT4088R, .96 hotside. 70mm mustang TB
Flamenco-T bosch fuel system, 1000cc injectors
NepTune RTP
I was wondering if the .96 hotside caused the tapering issue, but tegedrex's car held 32psi fine with the same turbo with the exception that his was non-BB. I will try a nice EBC and see what happens If you can imagine the dyno if the boost is held to redline..... well, the numbers will be quite a hit higher
Regardless of the #'s, this thing is a monster. I was never able to roast 4th gear withdrag radials and a quaife until now. I am hitting the track today.
HUGE Special thanks to Tim at TurboElements (wonderul product and customer service), Geoff at Full-Race for the countless hours of help over the years (thanks a ton man), Earl and Benson, Stan at Fast-turbo, all of Revolutions Tuning, Sam Parks and Kyle at ImportSports and of course the Big man upstairs
I will post an updated dyno chart when the boost is held to redline as well as some nice timeslips ASAP
Old Sep 6, 2006 | 09:32 AM
tegedrex's Avatar
Default Re: Turbo elements top mount manifold! (servion)
Nice as always Jeremy cant wait to see the times this evening. You are on a roll for the past couple of weeks
BTW you should send me the old beast laying on your garage floor for the smokey DA
Old Sep 6, 2006 | 01:26 PM
Kelly.'s Avatar
I've quit using this account
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboElements.com &raquo;</TD></TR><TR><TD CLASS="quote">The manifold has already been proven to make power, the same design made 441hp and 333ft lbs on a SOHC with a 57 trim @ 25psi. </TD></TR></TABLE>
turboelements have been great for me.
great product, great customer service
dion- besides the people in this thread there are a few others in vegas running tim's products
I highly recomend Tim and turboelements to anyone that will listen to me
Old Sep 6, 2006 | 02:33 PM
i ♥ snails
turboelements have some sick products. Im now convinced too use there parts on my turbo D. There located locallly also. props too them for a sick manifold and downpipe.
