h22 stoker turbo ?
h22 stroker turbo ?
http://www.pocketrocketsracing.com/hoh22stkit.html
I was wondering how that stroker kit will work out with boost ? Assuming im running low compression 90mm bore. I havent seen much about this particular stroker kit or much about h22 stroker turbo on here so i figured i would ask
Modified by kornerk12 at 12:07 PM 8/27/2006
Re: h22 stoker turbo ? (kornerk12)
first off, $.
secondly, https://honda-tech.com/zero...67579
IMO, you shouldnt be thinking about this stuff with forced induction unless you're trying to break some records and have money to burn. The stock geometry of an h22 can make A LOT of power with a turbo.
Re: h22 stoker turbo ? (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">Not needed in my opinion for a FI application.</TD></TR></TABLE>
yep true thats why u boost. for a n/a setup it would be a good option. though i would imagine it would make a larger sized turbo spool much quicker.
Re: h22 stoker turbo ? (93b16hatch)
But would it hold up well under boost ? With a shorter stroke and stock bore with say carillo h beams and cp pistons will it be able to handle more boost ? Darton or benson sleeves would be used.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93b16hatch »</TD></TR><TR><TD CLASS="quote">
yep true thats why u boost. for a n/a setup it would be a good option. though i would imagine it would make a larger sized turbo spool much quicker.</TD></TR></TABLE>
spool a bigger turbo faster but it would also shorten your powerband topend because of your new shitty rod/stroke ratio
Re: h22 stoker turbo ? (b16hybridsol)
read the description though it says its good to 9.5k. Would it still shorten powerband if thats true ?
vietkidracing
06-13-2006 01:37 AM
