help with hondata s300 launch control
Old Aug 30, 2006 | 02:16 PM
mike93eh2's Avatar
Default help with hondata s300 launch control
how should i hook up this stoplight switch for use with s300's launch control. or would it be easier to use the a/c switch or something?
i dont quite understand it though. is the switch just to activate it? and doesnt deactivate it? and your input for maximum speed is what deactivates it?
Old Aug 30, 2006 | 04:20 PM
Shmaa's Avatar
Default Re: help with hondata s300 launch control (mike93eh2)
just set it to always on, you can set it to deactivate at a certain MPH usually around 6 or so.
Old Aug 30, 2006 | 05:56 PM
96 GSR-T's Avatar
Default Re: help with hondata s300 launch control (Shmaa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shmaa &raquo;</TD></TR><TR><TD CLASS="quote">just set it to always on, you can set it to deactivate at a certain MPH usually around 6 or so.</TD></TR></TABLE>
What I did, mine shuts off at 6mph.
Old Aug 30, 2006 | 06:51 PM
OBRJosh's Avatar
Default Re: help with hondata s300 launch control (96 GSR-T)
Yup me too works perfect , only i wish it bounced alittle harder, anyone else notice theres a delay? im thinkin its my stock map though let me know thanks
Old Aug 30, 2006 | 06:54 PM
DRIVENRacing's Avatar
it wont do hat the aem ems or any standalone does, its a bit different, also the nti lag is hella slow, but it does the trick...
Old Aug 30, 2006 | 07:15 PM
OBRJosh's Avatar
Default Re: (adSPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adSPEED &raquo;</TD></TR><TR><TD CLASS="quote">it wont do hat the aem ems or any standalone does, its a bit different, also the nti lag is hella slow, but it does the trick... </TD></TR></TABLE> So its just the Hondata thats like that, slow bounces , casue i know the aem bounces likea ****
Old Sep 13, 2006 | 09:46 AM
correct.. as i said before, the aem and hondata or any honda ecu wont do the cut that the aem ems would..
Old Sep 15, 2006 | 07:16 PM
OBRJosh's Avatar
Old Sep 15, 2006 | 11:33 PM
96 GSR-T's Avatar
Default Re: (OBRJosh)
from the dead......
Old Nov 8, 2006 | 09:46 AM
InJ3cted's Avatar
Default Re: (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBRJosh &raquo;</TD></TR><TR><TD CLASS="quote"> So its just the Hondata thats like that, slow bounces , casue i know the aem bounces likea ****</TD></TR></TABLE>
back from the dead... someone has to have an answer
Old Nov 12, 2006 | 07:05 PM
Black DC2's Avatar
Default Re: (InJ3cted)
how did u get ur 2 step to even build boost i can only get like 1 psi out of my ****
set @ 5500 rpm we tried it @ like 7k and nothing only 1 psi
Old Nov 15, 2006 | 05:58 PM
dragsol's Avatar
Default Re: (Black DC2)
Pull about 9 degrees of timing and you will get flames and full boost.
Old Nov 15, 2006 | 06:21 PM
mike93eh2's Avatar
Default Re: (dragsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragsol &raquo;</TD></TR><TR><TD CLASS="quote">Pull about 9 degrees of timing and you will get flames and full boost.</TD></TR></TABLE>
im pulling 10 degrees... but no flames
Old Nov 15, 2006 | 06:24 PM
OBRJosh's Avatar
Default Re: (mike93eh2)
yea ive pulled up to 20degreese, adding fuel just about everything and did nothing, only way ive built decent boost was by preloading
Old Nov 16, 2006 | 03:34 AM
turbodav's Avatar
anyone with good working numbers like fuel =_________ timing =________
that has work well for them using hondata s300. thanks for your help
Old Nov 20, 2006 | 12:02 PM
turbodav's Avatar
bump ttt
Old Nov 26, 2006 | 05:41 PM
platinum00's Avatar
what do you guys mean by slow bounces?
platinum
Old Nov 26, 2006 | 05:48 PM
OBRJosh's Avatar
Default Re: (platinum00)
From what i gathered from hondata pull 40 degreese of timing , I got this info From Hondata forum ,but havent tried it cause my New engine is being built.
Old Nov 26, 2006 | 05:53 PM
B.'s Avatar
B.
400 HP Club
ive got my activated by my clutch...
Old Nov 26, 2006 | 05:54 PM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">what do you guys mean by slow bounces?
platinum</TD></TR></TABLE>
i get slow bounces when i dont preload..
when i preload it for some reason bounces real fast like MSD.
OBRJosh's Avatar
There exact repley to my post
You cannot build as much boost with the distibutor setup as a coil on plug as the retard is limited by the distributor. However is it possible to build a lot of boost on the line.
Set the activation rpm below the launch limiter. You have to experiment what works the best but 100 - 1000 rpm below the launch limiter should be a start. Next set the fuel enrichment to about 1/4 of the tables at full boost - probably 500-1500 or so. The set the ignition to -40 degrees (this will just peg the ignition timing to 5-10 degrees past TDC). Experiment with fuel based on EGTs and boost.
We can also try an ignition only cut for the launch limiter, if people think that will help
Old Nov 26, 2006 | 06:02 PM
platinum00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">
when i preload it for some reason bounces real fast like MSD.</TD></TR></TABLE>
i guess my question was, what bounces. the tach, your boost, etc..?
platinum
Old Nov 26, 2006 | 06:07 PM
OBRJosh's Avatar
The Rpms, its just not as fast as the AEM or Neptune Rtp
Old Nov 26, 2006 | 06:10 PM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">i guess my question was, what bounces. the tach, your boost, etc..?
no niether.. i dont know what bounces lol.. just the sound i guess.
Old Nov 26, 2006 | 06:11 PM
mike93eh2's Avatar
my activation is set 200rpms below the launch limiter and my fuel enrichment is 15 and retard ignition is 10
civicboy96
Engine Management and Tuning
Aug 19, 2008 09:47 PM
BUCK_NASTY
Apr 20, 2007 07:42 PM
xDicktonesx
51
Nov 11, 2006 11:16 AM
digital sol
Jul 27, 2006 05:15 PM
Kwuaymaikrup
Oct 23, 2003 12:06 PM
