Ignition breakup when hot
Old Aug 27, 2006 | 01:40 PM
93c1sol's Avatar
Default Ignition breakup when hot
Just recently whenever i get up to operating temp and get into boost a few times the ignition seems to be choppy at low rpms. If i'm cruising around 30-40mph and my foot is lightly on the gas it's all choppy and then once i give it more gas to accelerate it cleans up and is fine. If i'm cruising around 60-70 and hold the gas lightly to stay at a constant speed it does the choppy thing. I did notice one thing and that inside the distributor was some red dust, so somehow it got moisture in there. I don't know if when it gets hot the ignition starts breaking up cuz the dist. is taking a crap? Anyone have any ideas/suggestions on what is wrong?
Old Aug 27, 2006 | 04:40 PM
93c1sol's Avatar
Default Re: Ignition breakup when hot (93c1sol)
anyone? hmm...
Old Aug 27, 2006 | 04:55 PM
Calvinator's Avatar
bump because im having the same problem, but mine only happens sometimes. Check your sparkplugs, You could have the wrong gapping. What kind of plugs are u running?
Old Aug 27, 2006 | 04:58 PM
SOHC_MShue's Avatar
i doubt its your ignition breaking up if it isn't breaking up in high rpms under heavy load.
Old Aug 28, 2006 | 02:28 PM
93c1sol's Avatar
Default Re: Ignition breakup when hot (SOHC_MShue)
i'm running the BKRE7-11, i believe that's the number, they are gapped at .030
Luke_V-tec
Oct 2, 2008 02:25 PM
Cyber ITR
Sep 22, 2006 12:49 AM
b18psi
May 11, 2004 01:06 PM
ghettochild
Mar 1, 2004 05:35 PM
FAST94GSR
Oct 24, 2001 11:05 AM
