BOV question
Old Aug 28, 2006 | 07:57 PM
igotthaspirit's Avatar
Default BOV question
Im running a TD04H on a 96 LS. Im only boosting it around 8-10 psi. My problem is that even if I adjust the Blitz BOV all the way out Im still getting alot of compressor surge!! I checked the vacuum port and its good. I also pulled the valve off and made sure the plunger moves up and down freely. Is it possible that the spring is so stiff that it wont let the plunger come up even when its adjusted all the way out? Has anyone ever tried trimming the spring down to fix this? Thanks, any help will be greatly appreciated!
spoonmectr
Old Aug 29, 2006 | 07:47 AM
Got_soy's Avatar
Default Re: BOV question (igotthaspirit)
check the vaccume source
Old Aug 29, 2006 | 09:51 AM
Default Re: BOV question (Got_soy)
allready did that vacuum source is good. i tried where the pcv goes and then I tried where the brake booster goes. neither is working
Old Aug 29, 2006 | 12:42 PM
Synapse's Avatar
Check the diaphragm and where it mates with the body to make sure that there isn't a sealing issue. Vacuum is one of the toughest seals to get right. Especially when you need actuation to be fast. It might be a torn diaphragm or some leak in the assembly somewhere.
jep
Oct 12, 2006 05:46 PM
a1320addict
Apr 29, 2005 06:01 PM
sporkcrx
Mar 11, 2005 04:34 AM
bluels-t
Sep 27, 2004 01:45 PM
graphic
Sep 17, 2003 08:23 PM
