Who runs a stock fuel pump?
I tell doctors what to do
The search function has been down for a while now so I started a new thread.
I just want to know if anyone here uses their stock fuel pump successfully. I'm going to be running 8 psi t3/t4 turbo d setup and I really don't want to replace the fuel pump in my crx.
Anyone do this and have problems running lean etc?
Re: Who runs a stock fuel pump? (ILcrxsi1)
A Walbro is cheap. Why chance it? On a friend's car we were able to get to 320whp (I think, not sure of the fuel pressure) before it leaned out at 8000RPM. Next day he got a fuel pump and made 360whp revving to 9100RPM with no problems
Re: Who runs a stock fuel pump? (xsi-t)
I forgot to mention I'll be using hondata.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsi-t »</TD></TR><TR><TD CLASS="quote">A Walbro is cheap. Why chance it? On a friend's car we were able to get to 320whp (I think, not sure of the fuel pressure) before it leaned out at 8000RPM. Next day he got a fuel pump and made 360whp revving to 9100RPM with no problems</TD></TR></TABLE>Because, it's a pain in the *** to get to the fuel pump in a crx on jackstands in your garage. Especially on a car that has been in northern IL its whole life.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 »</TD></TR><TR><TD CLASS="quote">I forgot to mention I'll be using hondata.
Because, it's a pain in the *** to get to the fuel pump in a crx on jackstands in your garage. Especially on a car that has been in northern IL its whole life. </TD></TR></TABLE>
You only have to do it once Another reason I would do it. I wouldnt trust that old CRX fuel pump. It has been in there how long? The car I talked about above was a 2000 ITR
I had a simalar experence with my stock fuel pump leaning out on the top end. Changed to a walbro 255lph and problem solved.
With the set up mentioned in the first post I would say that the stock fuel pump would be at its limit. And if it is the stock crx pump it would be pretty old.
Re: Who runs a stock fuel pump? (katoeh2o)
i used a stock fuel pump in my b18c JRSC CRX with no problems for a year then i switched it out once i went turbo Switching the fuel pump is not hard at all in a crx. Just make sure you run your car almost out of gas. it didnt take long at all
I just put a walbro in my DA on jackstands, it's really not a big deal. Just get the car up high enough so you can drop the tank on your belly and roll out on the creeper.
Re: (ILcrxsi1)
well i think you are gonna make more than 200HP on 8PSI with a T3/T4.
so dont chance it, its not worth it...
or........do chance it and let us know what the breaking point was
Re: (agrn93ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agrn93ls »</TD></TR><TR><TD CLASS="quote">well i think you are gonna make more than 200HP on 8PSI with a T3/T4.
or........do chance it and let us know what the breaking point was</TD></TR></TABLE>I'm really only running sping pressure. With a tial with the .5 bar spring I think it's 7.25 psi. I just said 8 to be fair
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">walbros are less than $100 and take about 15 minutes to install.....why the hell would you cheap out on something so inexpensive?? </TD></TR></TABLE>
because some people are cheap and lazy
Not saying that the OP is either of the above......
Man U FTW
Re: (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 »</TD></TR><TR><TD CLASS="quote">
You'd have to be pretty cheap and lazy if you decided not to buy a Walbro. It has to be the easiest thing in the whole turbo setup to install and one the cheapest things too....
Re: (agrn93ls)
Breaking point is going to be different from car to car. Every car's wiring, alternator, battery, etc. is going to be different as far as conditions and working order
Re: (BoostedEG6)
Not saying that the OP is either of the above...... </TD></TR></TABLE>bingo <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aj99si »</TD></TR><TR><TD CLASS="quote">15 minutes to install a fuel pump in a crx. Obviously you have never changed a ful pump in a crx.</TD></TR></TABLE>nope
edit: would have searched to see how hard it is, but the search function was all screwed up yesterday. Hence the creation of this thread
Re: (ILcrxsi1)
It is not to hard but I will take more like 2 hours. If you allow time for some of the pain in the butt thingsthat can go wrong.
I think your stock one should be fine for your d-series. When I posted before I thought you were runnig your t3/t4 on a b-series. What are the specs on the turbo anyways.
My stock pump did fine on by b16 till I put a bigger turbo and ramhorn mani. Then I upgraded to a walbro.
Re: (katoeh2o)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katoeh2o »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>garrett T3/T4 AR .48 57 trim
Re: (Mr Wonderfull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Made 300 whp/300tq all day long for a year. Then got some bad gas and chumped a piston. </TD></TR></TABLE>
You sure it was bad gas?
