another intercooler piping????
Old Mar 7, 2007 | 08:20 PM
crvtkllr's Avatar
Default another intercooler piping????
i have a b16t set up right now and im runing the hot side with 2.5 plumbing and the same on the cold side, im making about 300 with this set up and im wondering if its going to hurt at all to run 2inch on the hot side and 2.5 on the cold side when i turn the boost up to make my 400 whp????
thanxs
Old Mar 7, 2007 | 08:23 PM
Schister66's Avatar
Man U FTW
it would be best to have 2.5" all around...
Old Mar 7, 2007 | 08:28 PM
crvtkllr's Avatar
Default Re: (Schister66)
would it increase my spool up time and still make decent hp if i was to go to 2in.??
on the hot side...
Old Mar 7, 2007 | 08:30 PM
Schister66's Avatar
Man U FTW
boost would come on slightly later because you have to fill more volume inside the piping, but if you dont get larger than a 2" you're going to be restricted if you plan to make more power....what is your setup?
Old Mar 7, 2007 | 08:34 PM
crvtkllr's Avatar
built b16t, riht now 300whp soon to come 400whp....thanxs
Old Mar 7, 2007 | 08:35 PM
Schister66's Avatar
Man U FTW
well what turbo are you using?
Old Mar 7, 2007 | 09:17 PM
dpetro1's Avatar
why would you change the IC piping in the first place? if you already have 2.5" i would just leave it. if spool time is what you are woried about, i dont think it would make that much of a difference. what IC and turbo are you using?
Old Mar 8, 2007 | 04:27 PM
crvtkllr's Avatar
Default Re: (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">why would you change the IC piping in the first place? if you already have 2.5" i would just leave it. if spool time is what you are woried about, i dont think it would make that much of a difference. what IC and turbo are you using? </TD></TR></TABLE>
i heard it would increase spool up time, im also using a spearco ic and a t3/t04e 57 trim turbo..
joppe
Aug 28, 2009 12:54 AM
Scheizty
Dec 4, 2007 05:46 AM
2ltrsnailpwr
Jan 29, 2004 06:40 AM
integranator
May 12, 2003 05:15 AM
