Firering?
Old Mar 7, 2007 | 02:08 PM
LVB18Civic's Avatar
Default Firering?
I was wondering if I really need the "firering" in my tial wastegate? On my old setup I didn't have it and it still boosted just fine. So what's the purpose of it?
Old Mar 7, 2007 | 02:16 PM
BoostedEG6's Avatar
Default Re: Firering? (LVB18Civic)
ummm yes..... its also called a valveseat
Old Mar 7, 2007 | 02:20 PM
sc4dr's Avatar
If your talking about the fire ring gasket, there junk. Just use high temp silicone. Most mating surfaces are machined so you'll be good.
Old Mar 8, 2007 | 08:22 AM
LVB18Civic's Avatar
so what is the reason for having this "firering"/valveseat? I want to know if it's worth buying it or not.
Old Mar 8, 2007 | 03:53 PM
sc4dr's Avatar
You don't need the gasket.
Old Mar 8, 2007 | 08:09 PM
LVB18Civic's Avatar
Default Re: Firering? (sc4dr)
It doesn't look like a gasket it's a big round metal seal. I think your thinking of something else.
Old Mar 8, 2007 | 10:27 PM
Heylookits shawn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote">If your talking about the fire ring gasket, there junk. Just use high temp silicone. Most mating surfaces are machined so you'll be good. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote">You don't need the gasket.</TD></TR></TABLE>
hes not talking about the gasket, hes talking about the little metal ring that goes inside!
not certian, but i would assume its so the valve gets a good seal, if not you would have exhaust gas leaking past it all the time. why its an extra peice instead of being part of the wg itself...i have no idea
Old Mar 9, 2007 | 02:56 AM
sc4dr's Avatar
Default Re: Firering? (Heylookits shawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">
why its an extra peice instead of being part of the wg itself...i have no idea</TD></TR></TABLE>
Thats why I assumed he was talking about the "fire ring" gasket, his wastegate should already have a seat, unless he bought it used maybe.
Old Mar 9, 2007 | 04:58 AM
BoostedEG6's Avatar
just spend the $30 they cost..... it is there to make sure that you have a good seat on your wastegate valve. When you install it, it pushes the valve up alittle bit to make sure its sitting on a flat surface and to where it wont leak....... If they where junk I am sure that Tial would not supply them from the factory and they would not come with all of their wastegates
Old Mar 9, 2007 | 07:03 AM
HiProfile's Avatar
Default Re: Firering? (BoostedEG6)
$30 bucks...I should take this 316ss scrap I have and make a couple.
The main deal with firerings is the preload on the spring. Too much and you get a small spike once it hits the desired boost level. Too little, and it will open a tiny bit and slow spoolup a little. Not even having it means there's usually a gap around the valve, which really affects spool/lag, as you're always leaking exhaust around the turbine.
Old Mar 9, 2007 | 05:39 PM
LVB18Civic's Avatar
Default Re: Firering? (HiProfile)
Ok, I understand now. That is probably why on my last setup I wasn't hitting boost till 5000rpm on my little 50 trim.
hondaeg8
May 31, 2006 12:56 AM
Tactic$
Oct 11, 2005 04:02 PM
IloveNewt
Jan 21, 2004 06:20 PM
SpeedMonkeyRacing
Oct 9, 2003 12:33 PM
JMinSi2000
Jun 23, 2002 05:06 PM
