my setup!!!
Old Mar 7, 2007 | 06:47 PM
IntegraGSR-Turbo's Avatar
Default my setup!!!
alright in the process right now..motor will be done by beginning of next week...here is what i got
b18c1
wiseco pistons...8:6.1 compression
eagle h-beam rods
4-layer cometic head gasket
arp head studs
rc 750cc injectors
walboro fuel pump
aem fuel rail
STILL NEED FPR
STILL NEED obd1 ECU
Tuning on chrome
t3t4 turo...TURBONETICS...STAGE II..REV HARD KIT already in
new oil and water pump timing belt etc...all new gaskets
using gsr cams
3-angle valve job
removed abs
apexi electronic boost controller
WHAT KIND OF POWER COULD I LOOK AT WITH THIS SETUP...any suggestions on anything i might need that i could forget
Old Mar 7, 2007 | 06:49 PM
Default Re: my setup!!! (IntegraGSR-Turbo)
oh and forgot one
golden eagle block gaurd
Old Mar 7, 2007 | 07:21 PM
bump for a reply
Old Mar 7, 2007 | 07:34 PM
da_dude's Avatar
400+ horsepower. Depend on the tune.
Old Mar 7, 2007 | 08:24 PM
Schister66's Avatar
Man U FTW
less than 400whp because that turbo will run out of breath
Old Mar 8, 2007 | 09:49 PM
Default Re: (Schister66)
why do you think it will run out of breath i heard they were good for 450...but im just saying...i am in now way sure at all
Old Mar 8, 2007 | 09:51 PM
Default Re: (IntegraGSR-Turbo)
also...today i sent my turbo back to turbonetics to get a rebuild...is $450 to much to pay...they said they would even give me a call back cuz it could cost as much as $550
Old Mar 8, 2007 | 10:08 PM
yee SERIOUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">less than 400whp because that turbo will run out of breath</TD></TR></TABLE>
agreed. ur kit seems to be limiting you. i would definitely upgrade if u want more than 400hp
Old Mar 8, 2007 | 10:16 PM
Default Re: (kidsafe yee)
really...what do yo think that my kit will max at
Old Mar 8, 2007 | 10:26 PM
da_dude's Avatar
You'll reach a little over 400 HP but pretty much maxing out the turbo. With a built bottom end like yours I'll get a turbo that will have more room to grow if need it to.
Old Mar 8, 2007 | 10:33 PM
Default Re: (turb20_vtec)
alright...well i am not sure but what size is the intake side of the turbo...if the exhause is .63 ar
Old Mar 9, 2007 | 11:48 PM
bump for more opinions
Old Mar 10, 2007 | 11:07 AM
morgan@synapse motorsport's Avatar
how thick is the head gasket? with the low compression pistons already in you dont wanna go with something too thick as it will drop your compression down very low.
2.5" downpipe on the kit will limit you, combine that and the turbo will probly run out of juice before you get to 400.
450-550 is a lot for a rebuild as brand new garrett t3/t04es are less than 600.
which would have also give you the option to sell you turbo and upgrade to a larger one.
Old Mar 10, 2007 | 01:47 PM
A.E Motoring's Avatar
good god, i would just buy a brand new turbo, and that turbo is good for like low 400s
Old Mar 11, 2007 | 08:04 PM
Default Re: (Dual Cam Racing)
yeah but...its still cheaper to rebuild it and...they will fully rebuild it...so it will be brand new
Old Mar 18, 2007 | 09:50 PM
bump
Old Mar 25, 2007 | 08:37 PM
alright talked to turbonetics on friday and they told me my turbo was an old model and pretty much everything was bad on it and they didnt carry the older parts anyway...so i have to get a new turbo...and i will...but in your opinion how bad is the 2.5 in. piping going to limit me and if i get the new turbo will i be able to get more power with my setup
fliptout2
May 27, 2006 01:27 PM
Boosted4
Nov 10, 2005 05:12 AM
preylude97sh
Oct 21, 2004 02:09 PM
RH+G
Jul 14, 2001 12:12 PM
