Differences in Garret T3/T04E 60 trim vs. Precision SC-5027E ????
So I'm at a fork in the road as to what the differences are between these 2 turbos other then price. So far I know they both have E comp housings, One has a 50 trim and the other is 60, both have .63 A/R exhaust.
Now I know the precision has a 360 race journal bearing in it but just to make sure does the garrett have one as well?
Any other specifics like, material used, weight, specs, etc...?
Like I was saying in difference of price the Garret goes for $555 shipped while the Precision is over $800?
I already have the precision SC-50 now but sucked something in and totally destroyed the CHRA and compressor wheel. I'm looking to upgrade slightly and leaning towards the 60 trim. Any suggestions?
Any info is appreciated
Moderator
Re: Differences in Garret T3/T04E 60 trim vs. Precision SC-5027E ???? (wickedEFguy)
Both the 50 "trim" and 60 "trim" use the same compressor wheel exducer size, but different inducer sizes, which change the characteristics of the turbo a bit. Both will use the same T31 stageIII exhaust wheel, and have similar sized exhaust housings, but the top range of the hp used on the 2 is very similar. The 60 trim may have a bit more to give in the top end, but a bit more lag becomes prevelent, especially in a VTEC motor b/w 2900-4000rpm range. Garrett typically offers their exhaust housing as a T31 4 bolt, with the 5 bolt SVO housing as an additional option for a bit more of a price. The Precision unit is offered with either housing for the same price.
Hope this helps a bit.
Modified by TheShodan at 6:33 PM 3/7/2007
This was exactly what I was looking for, thank you so much
So last question...what turbo's is the 360 degree bearing standard? You talked about how in the smaller size turbo's it will utilize the 270 degree bearing. Would this be in like a T3 .48A/R super 60? or smaller? What about the 60 trim that I want, does this have a 360 or 270?
The car it's going into is a B16 swapped CRX mostly daily driven, mostly just want to hit around 400 ponies and call it a day. This is why I'm leaning towards the 60 trim, not to ginormous and not too small for daily driven fun
thanx again
thanx again
Moderator
Re: (wickedEFguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedEFguy »</TD></TR><TR><TD CLASS="quote">This was exactly what I was looking for, thank you so much
thanx again</TD></TR></TABLE>
Daily Driver is a relative term and is very subjective. Most of the T3 series up until past the 60-1 and 61mm inducer sizes use a 270 degree bearing system in the Garrett world. If you are indeed trying to acheive 400whp on pump gas, then you need to go much larger than the "60 trim" T3/T4. Since 400whp is starting to leave its efficiency range, you may want to look to something else. You do not want to purchase a turbo that is out of its efficiency range when trying to run at such a higher hp on an everyday basis. That leads to a short life of a turbocharger.
KStuned
06-15-2007 05:31 PM
DRKSol
12-29-2004 03:20 PM
