Turbo kit price difference....?
Old Mar 5, 2007 | 07:15 AM
dezerte's Avatar
Default Turbo kit price difference....?
Why is this kit SO much more when buying directly from greddy? It doesn't make sense to me:
http://greddy.com/products/dis...ry=15
vs
http://www.sportcompactonly.co...w4S2g
It's almost a thousand dollars less...I don't know much about turbos, like what "trim" means or anything so I wanted to just buy a kit that was put together with parts that work well with each other, without paying too much. Looks like this is gonna be harder than I thought..
Old Mar 5, 2007 | 07:20 AM
Schister66's Avatar
Man U FTW
research more rather than wasting all your money on a setup like that...for the same price you can get something 10x better if you research and find out what you want. IMO those "kits" are garbage for the price
Old Mar 5, 2007 | 08:00 AM
dezerte's Avatar
Default Re: (Schister66)
I'm not sure how to tell the difference between good equipment and bad equipment. Otherwise I would just piece together my own kit. I know what parts you need, it's just that everything people post that they find on ebay, everyone always says its garbage. Oops
Old Mar 5, 2007 | 08:03 AM
BoostedEG6's Avatar
Default Re: (dezerte)
how much power are you looking to make? and how indepth are you going to go on your motor? like are you going to sleeve and do pistons and rods? or are you going to stay stock everything?
Old Mar 5, 2007 | 08:28 AM
dezerte's Avatar
Default Re: (BoostedEG6)
I want a really conservative setup. I'm going to keep the internals stock for now, I'm looking to make around 200~210hp to the ground.
Old Mar 5, 2007 | 08:53 AM
Schister66's Avatar
Man U FTW
you need to research more.....what engine/chassis is this for and what's your budget?
Old Mar 5, 2007 | 09:26 AM
dezerte's Avatar
It's for a 1999 integra LS. B18b1 engine
Just got done reading these articles: http://www.turbominivan.com/tech/turbo201.htm
I'd like to keep the entire process of turbocharing under 2k (before tuning)
Old Mar 5, 2007 | 10:39 AM
dezerte's Avatar
Would this Turbo and Manifold be a good combination for the build I have in mind? (Looking for ~210 hp on stock internals, I want to start hitting boost at ~3krpms if that's possible)
Also, how do I know they are compatible? Because they are both T3?
Manifold: http://cgi.ebay.com/ebaymotors...QrdZ1
Turbo: http://cgi.ebay.com/ebaymotors...QrdZ1
Old Mar 5, 2007 | 11:08 AM
Schister66's Avatar
Man U FTW
you're not a trial member anymore so check out the Marketplace...i WILL NOT buy anything from Ebay for my car
http://www.hondamarketplace.com
GsrVtec
Sep 6, 2006 04:40 PM
NITERYDER
May 22, 2004 09:46 AM
shibby
Oct 5, 2003 06:58 PM
bLuEciVicGuY
Jun 25, 2003 08:46 AM
MugenPoweredLude
Oct 25, 2002 07:20 AM
