fmu
Old Mar 5, 2007 | 07:21 PM
joshfish79's Avatar
Default fmu
why is an fmu so bad? im building a stock b16 with a turbo it will run 10psi boost and its in a gutted crx. is there any reason why an fmu would not work?
Old Mar 5, 2007 | 07:37 PM
tegasaurus's Avatar
Default Re: fmu (joshfish79)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joshfish79 &raquo;</TD></TR><TR><TD CLASS="quote">why is an fmu so bad? im building a stock b16 with a turbo it will run 10psi boost and its in a gutted crx. is there any reason why an fmu would not work?</TD></TR></TABLE>
it'll work, it'll just suck. you have no precise way to control the fuel input. you have no control over ignition. 12:1 fmu = 12psi of fuel is added for every 1 psi. so at 10 psi, you're 120psi over factory, which is about 38-42.
160+ psi fuel rail pressure = fuel injector failure = motor gbye. and they run lean.
fmu = **** motors up.
Old Mar 5, 2007 | 08:23 PM
s2kdre's Avatar
Default Re: fmu (tegasaurus)
fmu is good for 5-8psi, but it will be a little rich compared to tunned set up, i ran an fmu for a year and never had problems, but some people blow their motor and blame it on the fmu.
Old Mar 5, 2007 | 09:54 PM
stockb18c's Avatar
^ ya thats what im thinkin to i ran my car on 8 psi and my buddy is runnin 9 psi on his car for about a year and no problem...
Old Mar 5, 2007 | 11:24 PM
avotegra's Avatar
Default Re: (stockb18c)
wat about a 10:1 ration fmu......is that better......or should i stick with big money and buy a hondata s200 with boost option
Old Mar 6, 2007 | 10:23 AM
stockb18c's Avatar
10:1 is worse..and yes go with the hondata more hp and better overall
Old Mar 6, 2007 | 11:07 AM
genocide43110's Avatar
All I have to say is I am running a 12:1 FMU right now and I swear I used like 2 gallons of gas in like 15 miles........ But I was going in an out of boost a lot. I'm running 5 psi right now.
Old Mar 6, 2007 | 11:21 AM
s2kdre's Avatar
Default Re: (genocide43110)
if u stay out of boost the gas milage is pretty good.
Old Mar 6, 2007 | 11:28 AM
Default Re: (s2kdre)
Well I would if I could but I have a .48 A/R T3 from a Saab on my H23 and it's to small and spools at about 2500 RPM. I think I'm just going to get a SAFC and some DSM 450's. My car is an auto and I had a lot of people tell me that there aren't really any ECU's I can use. I did hear someone say that I might be able to chip and use a P75 or it was a P72. I don't remember but I think I'll just save up and get a SAFC. I also need to get a Walbro.
Old Mar 6, 2007 | 12:37 PM
Schister66's Avatar
Man U FTW
For the amount of money you're putting into a setup, you might as well go ahead and get a decent amount of power out of it. An FMU is your last feasable option on a turbo setup....look into Crome or Uberdata....if you're really looking for a cheap alternative, you can get an SAFC and learn to tune it yourself....
Old Mar 6, 2007 | 12:48 PM
mtber's Avatar
fmus make cars go boom
Old Mar 6, 2007 | 01:06 PM
TurboIntegra's Avatar
10psi X 12= 120 + 38psi factory= 158psi
158psi, does that sound safe to you?
Old Mar 6, 2007 | 01:08 PM
avotegra's Avatar
Default Re: fmu (TurboIntegra)
i dont really know..........is that to much or wat.........see i dont know........
Old Mar 6, 2007 | 02:12 PM
96vtecI4's Avatar
i'm selling my crome chipped ECU
Old Mar 6, 2007 | 02:27 PM
b18sihatch's Avatar
Default Re: fmu (avotegra)
i find it amazing that people are willing to build a setup and cheap out on the most important part of a motor.
TUNING! IS PRIME Fing KEY!
Fuel injectors
Fuel pressure regulator
Fuel pump
Fuel rail
hondata/crome/uberdata/ect
it is the most important part of any motor setup that is boosted why cheap out and have to buy another motor?
Old Mar 6, 2007 | 02:38 PM
96vtecI4's Avatar
You can get away with emanage or emanage ultimate.
Old Mar 6, 2007 | 02:39 PM
b18sihatch's Avatar
Default Re: (96vtecI4)
but not even emanage is that great compared to other chipped ecu alternatives
Old Mar 6, 2007 | 03:01 PM
96vtecI4's Avatar
no but fmu is the closest to nothing you can get.
Old Mar 6, 2007 | 03:04 PM
b18sihatch's Avatar
true i would probably choose nothing if i had to choose fmu lol, its so crazy that people will spend good money over bad its insane to ave a build and cheap out in important parts of the motor build crazy
Old Mar 6, 2007 | 09:24 PM
joshfish79's Avatar
so the only reason not to run an fmu is too high or too low fuel pressure. what about adjustable fmus? i see these on turbo sandrails all the time and dont hear about any issues.
Old Mar 6, 2007 | 09:35 PM
joshfish79's Avatar
as far as money spent.
running and driving 90 crx si with b16a swap $200
pieced together turbo kit $800
in all reality im not spending that much on this build.
Old Mar 6, 2007 | 09:40 PM
joshfish79's Avatar
96vetecI4 how much do youwant for your chrome? is it obd0, obd1 or obd2?
Old Mar 6, 2007 | 09:59 PM
96vtecI4's Avatar
OBDI and $400 canadian
jspecegseis
Apr 19, 2007 05:16 AM
f1 vtec
Aug 28, 2004 07:50 PM
kovert
Aug 17, 2004 09:58 AM
alfee
Nov 4, 2003 09:05 PM
RTW DC2R
Jun 5, 2002 07:41 AM
