crank?
Old Mar 7, 2007 | 07:46 PM
CeeJayy's Avatar
Default crank?
so im doing a poor mans type r and was wondering what crank would work the best? i hear people are using ls crank with gsr block but...
Old Mar 7, 2007 | 10:06 PM
RJH6's Avatar
Default Re: crank? (CeeJay16)
ls crank you will get more torqe, but loose top end. gsr crank you will have the best results...
Old Mar 7, 2007 | 10:41 PM
boosted92's Avatar
Default Re: crank? (RJH6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RJH6 &raquo;</TD></TR><TR><TD CLASS="quote">ls crank you will get more torqe, but loose top end. gsr crank you will have the best results...</TD></TR></TABLE>
What a crack-*** post. Lose top end because of the LS crankshaft? No. Go search for some results people are having with K-series motors. Seeing BIG gains everywhere swapping from an 86mm to a 99mm crank (K20 to K24). How do you figure he's going to lose some top end power by having 1.8mm more stroke? Way to pull that one out of your ***
Old Mar 8, 2007 | 09:36 AM
CeeJayy's Avatar
Default Re: crank? (boosted92)
bump
Old Mar 8, 2007 | 09:55 AM
BoostedEG6's Avatar
just run an LS crank inside a GSR block. You will have to use LS rods and Pistons also you will make good power... also be sure to use the GSR main caps and girdle and you wont have a problem reving it high
Old Mar 8, 2007 | 07:40 PM
CeeJayy's Avatar
Default Re: crank? (BoostedEG6)
so out of b16 ls and gsr. ls ftw? also i will boregsr block and plan on using wiseco pistons and eagle rods that will work with ls crank right?
Old Mar 22, 2007 | 09:57 AM
CeeJayy's Avatar
Default Re: crank? (CeeJayy)
bump
Old Mar 22, 2007 | 10:07 AM
BoostedEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CeeJayy &raquo;</TD></TR><TR><TD CLASS="quote">also i will boregsr block and plan on using wiseco pistons and eagle rods that will work with ls crank right?</TD></TR></TABLE>
are you running a sleeved block or stock sleeves? If stock dont go bigger than 81.5.....yes you can use wisecos and eagle rods just make sure they are for a LS
Old Mar 22, 2007 | 10:10 AM
CeeJayy's Avatar
yeah deff sleeving it. and thanks
Old Mar 31, 2007 | 08:18 PM
RJH6's Avatar
If you look at dynos the gsr crank give you the best all around results, it been proven. but if you use a ls crank you have to get rid of the oil squrters witch help lube the motor at high rpms. thats why you should use the gsr crank....
Old Mar 31, 2007 | 09:37 PM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RJH6 &raquo;</TD></TR><TR><TD CLASS="quote">If you look at dynos the gsr crank give you the best all around results, it been proven. but if you use a ls crank you have to get rid of the oil squrters witch help lube the motor at high rpms. thats why you should use the gsr crank....</TD></TR></TABLE>
That's interesting I thought that most people blocked the oil squirters in built motors because they are unneeded and if you block them you increase your oil pressure everywhere else. Am I confused??
Old Mar 31, 2007 | 09:55 PM
Top Ramen's Avatar
Default Re: crank? (KeyserSoze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">That's interesting I thought that most people blocked the oil squirters in built motors because they are unneeded and if you block them you increase your oil pressure everywhere else. Am I confused??</TD></TR></TABLE>
No reason for squirters if you run forged slugs.
Old Mar 31, 2007 | 09:58 PM
SD_Lurker's Avatar
HT White Ops
Default Re: crank? (Top Ramen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top Ramen &raquo;</TD></TR><TR><TD CLASS="quote">No reason for squirters if you run forged slugs.</TD></TR></TABLE>
So what are these guys using to plug them? Anyone else have any input? I would like to know myself as I am building a GSR bottom end. Sure you might gain some oil pressure but is it worth it?
Old Apr 1, 2007 | 12:57 AM
SwappedTURBOegg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">
What a crack-*** post. </TD></TR></TABLE> haha werd
Old Apr 1, 2007 | 06:08 AM
sc4dr's Avatar
Default Re: crank? (SwappedTURBOegg)
I had my squirters welded shut, using a 95mm eagle crank in a gsr mill.
Old Apr 1, 2007 | 08:13 AM
Top Ramen's Avatar
Default Re: crank? (SD_Lurker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker &raquo;</TD></TR><TR><TD CLASS="quote"> So what are these guys using to plug them? Anyone else have any input? </TD></TR></TABLE>
It took me only a few seconds to do a search in the archives using "plug squirters" that produced three threads mentioning the Golden Eagle squirter plug kit. Its about $15.
Last time today I spoon-feed anyone information that is so easy to find. . .
Old Apr 1, 2007 | 11:52 AM
doood's Avatar
been there done that
so where are these dyno's you speak of?
the squirters are not there to lube the engine. they spray at the underside of the pistons.
TurboCivicR93
Aug 18, 2012 02:33 PM
insidiouseg-6
23
Jul 30, 2008 10:45 PM
ProjectBoosted
Oct 23, 2006 10:02 AM
BryanEk
Feb 27, 2005 06:14 PM
