dual charged sohc??
Old Mar 6, 2007 | 11:30 AM
JDMJNKY's Avatar
Default dual charged sohc??
What's up guys? I'm wanna build a twin charged honda using a jrsc & a greddy equivalent TC! The problem is I want it all to look stealth...STOCK! The plans will be for a built d16 w/ piston compression in the 9's hopefully. I have no specific WHP/HP target, but I was thinkin max 20psi(8 jrsc & 12 TC) between the two. I've did my fair share of searching but nothin clear & dry saying this is what needs to be done for sucess??? any help would be greatly appreciated.
Old Mar 6, 2007 | 11:32 AM
underpressure02's Avatar
Default Re: dual charged sohc?? (JDMJNKY)
WHY????
Old Mar 6, 2007 | 12:05 PM
JDMJNKY's Avatar
Default Re: dual charged sohc?? (underpressure02)
To compensate for the low torque of a d-series turbo lag!
Old Mar 6, 2007 | 12:10 PM
95jeremie's Avatar
https://honda-tech.com/zerothread?id=1754535
Old Mar 6, 2007 | 12:23 PM
95jeremie's Avatar
Default Re: dual charged sohc?? (95jeremie)
i still have the vid somewhere it might take me a day or so to find it so let me know if you want it and i will start the hunt.
Old Mar 6, 2007 | 01:57 PM
JDMJNKY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jeremie &raquo;</TD></TR><TR><TD CLASS="quote">i still have the vid somewhere it might take me a day or so to find it so let me know if you want it and i will start the hunt. </TD></TR></TABLE>
Let the hunt begin! I'm gonna do this I just need more info. And to see if there has been any technological adv. To make this easier and less complicated.
Old Mar 6, 2007 | 02:20 PM
92LSVTEC's Avatar
holy crap.... you are nuts.... GL with it though.... id love to see it actually work!
Old Mar 6, 2007 | 02:31 PM
b18sihatch's Avatar
You must have deep pockets to afford the setup, however i dont really feel it would be all that much better over a quality turbo kit with great tune and great fuel and EMS...cant really say it will be that much better.
if money wasnt a option why not sleeve it and bore it larger to make more torque and invest in a quality turbo kit?
Old Mar 6, 2007 | 02:41 PM
JDMJNKY's Avatar
Default Re: dual charged sohc?? (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">You must have deep pockets to afford the setup, however i dont really feel it would be all that much better over a quality turbo kit with great tune and great fuel and EMS...cant really say it will be that much better.
if money wasnt a option why not sleeve it and bore it larger to make more torque and invest in a quality turbo kit?</TD></TR></TABLE>
Well considering the jrsc is only 800 and I'm gonna build my own kit roughly a 1G that's not expensive. I can do assembly myself! Pistons, rods, block gaurd 800 for a grand total of 2600 that's not bad for a built motor dual charged! I'm sure there will be addtn'l $$$ needed but not as drastic as you make it sound.
Old Mar 6, 2007 | 02:44 PM
b18sihatch's Avatar
you will also need some good fuel management and engine management.
along with all of the little odds and ends that kinda kit would come to.
plus getting soemone to tune it might bwe a hassle might not be, and might be a good ammount of time to get the dual charging right
Old Mar 6, 2007 | 02:52 PM
JDMJNKY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">you will also need some good fuel management and engine management.
plus getting soemone to tune it might bwe a hassle might not be, and might be a good ammount of time to get the dual charging right</TD></TR></TABLE>
Well for fuel mngt. I was thinkin hondata as for tuning I know 3 ppl. Who do tunning! Accredited stuff! (Not givin out any names, lol )
Old Mar 6, 2007 | 02:56 PM
sc4dr's Avatar
PM rmcdaniels, and clemson hatch, they have first hand experience doing the dual charger thing. Clemsonhatch has a pretty nasty autocross civic, that takes names every event. Good luck
ExospeedAMcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJNKY &raquo;</TD></TR><TR><TD CLASS="quote">To compensate for the low torque of a d-series turbo lag! </TD></TR></TABLE>
Whaat? If there was lag, its only at very low RPM 1-3K, And when are you ever at that RPM?
If you have the proper turbo sizing setup, you'll minimize the lag and at the same time, gain at top end. And as far as using a SC to compensate for the low end, thats just ridiculous to try to gain power at low rpm like that. who needs it.
b18sihatch's Avatar
whynot sleeve and bore the block, then you can have a larger bore for more tq, even if you are still dual charging
Old Mar 6, 2007 | 03:03 PM
JDMJNKY's Avatar
Default Re: dual charged sohc?? (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">Whaat? If there was lag, its only at very low RPM 1-3K, And when are you ever at that RPM?
If you have the proper turbo sizing setup, you'll minimize the lag and at the same time, gain at top end. And as far as using a SC to compensate for the low end, thats just ridiculous to try to gain power at low rpm like that. who needs it.</TD></TR></TABLE>
Have you seen the graphs?? Prolly not b/ that's an uneducated comment!
Old Mar 6, 2007 | 03:08 PM
JDMJNKY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">whynot sleeve and bore the block, then you can have a larger bore for more tq, even if you are still dual charging</TD></TR></TABLE>
I just hate lag Period! I want kinda a zero lag sys. Which only a small turbo could possibly be able to acheive if I just do the tc, but that will limit top end. Also I do plan to attend track events!
civhatch90's Avatar
have you even built a turbo charged or supercharged set up before? it would sound reasonable to start with either and once its running see what you would need to do the other half
Old Mar 6, 2007 | 03:11 PM
b18sihatch's Avatar
thats kinda what im saying.
like take my 1.8T jetta for example.
it makes 174TQ at 1950RPM, its only turbo charged, you really couldnt expect to see any lower rpm torque than that, at least to the fact traction will be come a major issue with really low rorque depending on how much you make
if you were to supercharge the jetta i dont believe it would make any lower rpm torque as that is pretty low.
my point? that a well devloped turbocharged engine can function like a SC but only not SC, if that makes any sense.
a d16 with a 28rs turbo would be imo just as good
Old Mar 6, 2007 | 03:19 PM
Have you seen the graphs?? Prolly not b/ that's an uneducated comment!</TD></TR></TABLE>
I believe I have seen and dealt with more Hondas that you can ever imagine. We have worked and built race engines setups for Drag and Road race cars that most people would drool over. I was driving turbo single cams and doing up all motor single cams when you were still in Elementary school. I think my comment is VERY educated.
JDMJNKY's Avatar
Default Re: dual charged sohc?? (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">You made my night at work lol
trying to talk smack and wanting to supercharge and turbocharge a D-series
Thats like 5x not worth it, its more money than you are obviously thinking (sure you know tuners but they cant get you free hondata) and its not worth all the hassel when if you knew what was going on...a proper sized setup will kick ya in the pants from 3k-redline. Do you not launch your car at all? The only time you wouldnt have power is from a dead stop limping it off the line, and if thats ones idea of 'racing' or driving aggresively than just keep your car stock, its a lot cheaper and even your idea wont take that away.
The guy who posted pics on turbod16.com never gave us anymore info, but I never heard anything positive come from it.</TD></TR></TABLE>
yes you know your ****, yeah others know their **** but why wait for 3500 when I can have it instantly? Off the line from a dead stop or wether I'm launching it!
Old Mar 6, 2007 | 03:25 PM
JDMJNKY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">I believe I have seen and dealt with more Hondas that you can ever imagine. We have worked and built race engines setups for Drag and Road race cars that most people would drool over. I was driving turbo single cams and doing up all motor single cams when you were still in Elementary school. I think my comment is VERY educated. </TD></TR></TABLE>
If its been proven, why are you against it? What have you built that can out do mcdaniels setup on or off the track w/ the same chassis and motor? I'm not here to hate, but most of you guys are giving me negative feedback but have never done it! That's the same as you telling me what I have or haven't buillt, what I know or don't know!
JDMJNKY's Avatar
If its been proven, why are you against it? What have you built that can out do mcdaniels setup on or off the track w/ the same chassis and motor? I'm not here to hate, but most of you guys are giving me negative feedback but have never done it! That's the same as you telling me what I have or haven't buillt, what I know or don't know! That just pushes me to do it more & more successfully!
Old Mar 6, 2007 | 03:36 PM
93supercoupe's Avatar
do it and get back to us.
Why are u stuck on D's anyways, Rota92 knows first hand they are junk
J/k Ryan, u know me and Noah still have love.
Old Mar 6, 2007 | 03:37 PM
sc4dr's Avatar
I was driving turbo single cams and doing up all motor single cams when you were still in Elementary school. </TD></TR></TABLE>
Hahaha I love it. If you want to be different, than go for it. But if you want a realistic, and reliable street setup, definitaley just go turbo.
Old Mar 6, 2007 | 03:40 PM
sc4dr's Avatar
Default Re: dual charged sohc?? (sc4dr)
btw, keeping belts, and pullies up to par is a pita. Not to mention all the crap that'll be in your engine bay.
